Question about PC Chips M756LMRT+ PII/III/Celeron Slot1/Skt370 mATX MB (MBPCM756LMRT) Motherboard
Pc was downloading updates, now restarts continually and no keyboard
Someone elses pc, they brought it to me after they tried fixing. I am at a loss. I have tried the keyboard on my pc and it works fine. Cannot get into bios, cannot start in safe mode. Count not do anything even if I could get into either with no keyboard. XP Home Update was Explorer 8
  • PC Chips Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps you
Posted on Feb 23, 2012
My anitvirus software wont upload. It is continually updating and restarting, non stop. It interrupts my entire work flow. If I update, it restarts, then immediately updates again and again. ALL DAY.
If your PC shuts down while trying to access an Anti Virus Software, you have a Virus already on your computer. Download Malwarebytes it's free to use and should solve any problems. Once you've downloaded it I would suggest turning off WiFi or disconnecting from the internet I case someone is remote viewing without permission.
Oct 19, 2013 | Trend Micro Smart Surfing for Mac
Key board
Desktop or Laptop keyboard ???....
Make sure the Ps 2 or the usb lead connections are secure (if applicable)
Make sure the batteries have charge and are getting good contact (if applicable)
Try blowing out all of the dust from your keyboard using a fine air blower from an air compressor or a can of compressed air making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
If this does not fix the problem
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
if your computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
Note: it will find all of your outdated drivers
You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Sep 12, 2013 | Computers & Internet
Acer wireless keyboard
May 19, 2013 | Acer Aspire All-in-One Desktop PC - Silver...
I was given this pc by my cousin,I was trying to reinstall Winxp to establish ownership. When I was finished there was a bunch of hardware things missing,long story short , I tried to load the drivers and...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://ct.download.com/clicks?t=1169844150-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5 Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. it might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions this will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Apr 05, 2013 | Dell Dimension 2400 PC Desktop
My keyboard won't turn on
Which operating system ?
Make sure the Ps 2 or the usb lead connections are secure (if applicable) Make sure the batteries have charge and are getting good contact (if applicable) Try blowing out all of the dust from your keyboard using a fine air blower from an air compressor or a can of compressed air making VERY sure there is no MOISTURE in the lines. dust causes static which causes lots of problems with a computer and its parts If this does not fix the problem Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html it might take some time being a freeware driver solution Note: it will find all of your outdated drivers You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. this will apply to your mouse as well if your computer came with a motherboard disc the drivers could be on it diconnect the keyboard then reconnect it then reinstall the driver make sure the lead has a secure seating if applicable or the usb device or restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
Feb 17, 2013 | E-Machines eMachines Desktop PC
Keyboard dont work
Make sure the Ps 2 or the usb lead connections are secure (if applicable) Make sure the batteries have charge and are getting good contact (if applicable) Try blowing out all of the dust from your keyboard using a fine air blower from an air compressor or a can of compressed air making VERY sure there is no MOISTURE in the lines. dust causes static which causes lots of problems with a computer and its parts If this does not fix the problem Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html it might take some time being a freeware driver solution Note: it will find all of your outdated drivers You will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated. Hope this helps.
Jan 13, 2013 | Computers & Internet
No power
Jan 10, 2013 | Computers & Internet
Input not supported
Keyboard ?
Hope this helps.
Nov 25, 2012 | HP Pavilion a1610n PC Desktop
Dell dimension 8200 keyboard compatibility- won't
From what I understand you have a compatibility issue with your new keyboard.
Here is what you can do, because it's probably a driver issue.
Youcan check if you are missing drivers by going to Start>(RightClick)My Computer>Properties>Hardware>Device Manager. If yousee any drivers that are yellow or with a ! those are the drivers youneed to find, download and install.
Windows Updates ~ When you go to Windows Update, do not "Express"update, rather "Custom" - Once it has loaded the screen, on the lefthand side you will see hardware. Download the hardware drivers there.They work 98% of the time, and Windows Update is pretty good now daysso it might fix your problem easy.
I don't understand the question entirely however.
Does your original keyboard work?
Is the new keyboard the only one not being reconizied?
Try differen USB ports, see if it makes a difference. Also, turn off the PC, and then plug it in. Sometimes the PC has to be restarted/turned off, before you change hardlike like keyboard and mouse or other accessories.
Hope I've been of some assistance!
Jul 02, 2009 | Dell Dimension 8200 PC Desktop
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
PC Chips M756LMRT+ PII/III/Celeron Slot1/Skt370 mATX MB (MBPCM756LMRT) Motherboard Logo
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
