Question about Car Audio & Video
ROCKFORD FOSGATE T-3000bd POWER AMPLIFIER
AMP BLEW 300 A ANL FUSE TURNED OFF MY SUV TO REPLACE THE FUSE WITH ANOTHER 300 A ANL FUSE AS SOON AS HEAD UNIT TURNED ON THE AMP SPARKED AND BLUISH GREY SMOKE FILLED THE REAR NOW I DROPPED THE AMP OFF TODAY TO AN ELECTRONICS REPAIR SHOP IF ANYONE HAS SOME KIND OF GUESS ESTIMATE ON THE WORST CASE POSSIBLE REPAIR COST I JUST DONT WANT TO GET TAKEN ADVANTAGE OF THANKS
  • 3 Answers
You blew up the DC-DC converter in the power supply. The whole PS is going to have to be rebuilt not to mention I am sure some output transistors are bad as well which caused the failure. I would say you are looking at $200 min charge. Those amps are nice and very well built.
Posted on Oct 02, 2009
  • 185 Answers
U probley just cooked the amp cant tell u how much and i say that for every body so dont be stupid asking q. and a's like that
Posted on Oct 31, 2008
My rockford fosgate T1 amp blew a fuse and now protection is on
Chances are that more than a fuse went. I would follow (internally) the path of the wires from the speaker you mentioned - inside the amp. This should bring you out to the main amp. I think you will find that whatever powers that channel is faulty.
Apr 10, 2013 | Rockford Fosgate FAP T1 Amplifier
What fuse and fuse breaker should i run with this amp? thanks
100 amp should do it. Put the fuse or breaker as close to the battery as possible. Beware of cheap round glass type fuse holders. If going with a fuse i recomment the ANL type. The ANL fuses are actually screwed to the fuse block and give a much tighter, more reliable connection.
Apr 18, 2010 | Rockford Fosgate T15002 Car Audio...
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
Apr 02, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Rockford fosgate p 300-1 amp will not turn on
plug your ground, battery, and remote wires only and see if it turns on when you turn your radio on, if not it must have blown. wiggle or move the connection block(where your wires are connected) and see if it tries to turn on. if so, your leads need to be re-soldered since they tend to go cold(they're not making good contact). But again, if that does not help, then your amp is gone.
Mar 18, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Amp not working
It sounds like you either blew a fuse, or you cooked your amp. The fuse on the P200.2 amp is a 30A fuse, and it sits right next to the power, ground, and remote wire connections on the end. Pull the fuse out and see if it's blown. You should also check any other fuses that you have in the car before the amp.
Mar 03, 2010 | Rockford Fosgate Punch P2002 Car Audio...
I need schematics for the rockford fosgate t1000.1bd power amp
bullet.gif 0°/180° Phase Switch bullet.gif 1/0 Gauge power/ground connectors with ANL fusing bullet.gif 12dB or 24dB/octave selectable crossover bullet.gif Audiophile grade speaker connections bullet.gif Best in class 4 oz. copper traces bullet.gif Infrasonic filter bullet.gif MasterSync - allows 1 amplifier to control an array of amplifiers bullet.gif PowerSync - allows 2 amplifiers to be "strapped" together bullet.gif Stealth Connections
http://www.rockfordfosgate.com/products/product_details.asp?item_id=95251
Feb 22, 2010 | Car Audio & Video
Amp
There is no reset button. If you disconnect all of the speaker wires from the amplifier's speaker terminals and unplug the RCA cables, does the protect light still come on (I assume that you've already replaced the fuse)?
Jan 12, 2008 | Rockford Fosgate P6001BD Car Audio...
Rockford Fosgate Power T20001bd goes into protect upon power up.
In most of Rockford's amps, the low voltage detection is connected to the remote input. If the remote voltage is too low and they use the same circuit on this amp, it could trigger the protection circuit.
Disconnect the head unit's remote from the amp. Use a fuse holder with a 3 amp fuse to jump between the B+ connection and the remote terminal of the amp. If the amp powers up, the head unit's remote output may be defective. If it blows the fuse, the remote input or part of the power supply is damaged. Do not try it with an unfused jumper.
Oct 21, 2007 | Rockford Fosgate T20001 bd Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Car Audio & Video Logo
298 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
