Question about Polaroid M635 Digital Camera
Won't read my memory card
I read the manual and it said 1 GB max. I put in a 16mb SD card and it won't recognize it either--is ther a bad connection-where can I get this fixed and will it be worth it?
  • 423 Answers
Did you format the card in the camera before you tried to use it? Do that first and it will probably work. Also, check to make sure the switch on the side of the card is not in the locked position.
Rob
Posted on Mar 03, 2009
Camera saying memory full but card brand new
Not only the size is important, the manual says SD max 2 GB.
But even a 1GB SDHC card won't work, because the camera is not compatible with SDHC and SDXC.
They used to make SD cards up to 4 GB, but most new cards from 1 GB and up are SDHC and above 32 GB the cards are SDXC. Older camera's can't handle these cards, although they look the same.
To read more and to understand compatibility from device versus Memory card, read this:
Secure Digital Wikipedia the free encyclopedia
Apr 10, 2015 | Samsung Digimax D73 Digital Camera
Is there a maximum SD memory card that I can use on my Panasonic Lumix DMCZ7. I have tried to use a 16 & 24Mb SD card but the camera will not read it and displays a ' card error reading message'
I think you mean 16 and 24 GB (Gigabyte), not MB, but those would not be SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If you really mean 16MB, then that would be rather small, not too big. 16MB is definitely compatible with the camera and is mentioned in the manual.
The maximum memory card size mentioned in the manual is 1GB, and that is quite big enough. If you really need more space, then just carry a spare, like people used to take extra film with them on holiday.
Dec 09, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Can i use a 4gb memory card
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00606/C743_GLB_en.pdf
P.50 of the above manual has a table that goes up to 1 GB for an SD card.
But, the FAQ's say that Easy Share cameras can use up to 2 Gigabytes for the SD cards.
Since your camera is from an XP Windows System era, I wouldn't expect that a 4 gb SD card would work in your camera (since it is that old).
http://selfservice.kodak.com/service/panels/solution/printSolution.jsp?solutionId=1170&t=solutionTab&ft=searchTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&viewMode=NORMAL&windowType=SAME&highlightInfo=&isRecord=false
The FAQ seems to indicate, again, that 2 Gigabytes is the maximum for an SD card (which your C743 digital camera uses).
The instruction manual seems to indicate that 1 Gigabyte is the max in the table.
Therefore, I would try the 2 Gigabyte one and if it doesn't read or format, then I would use the 1 Gigabyte as the max. for this camera, and return the 2 Gigabyte SD card.
Aug 08, 2010 | Kodak EasyShare C743 Digital Camera
Where do you put the memory card in on nintendo ds
memory card on a dsi goes in the bottom right, it's labeled SD CARD, and the whole plastic piece will hang lkoosely after you pry it.
Aug 29, 2009 | Nintendo DS Console
Problem with SD card for Hitachi DZMV550A
Never mind, just ignored my posted note.
I just get confused . Had been tried to follow the instruction manual book, but the book doesn't mentioned max capacities of the SD memory card, so I called Hitachi Service Hotline, and they gave me helpful hints which is I should use max 1 GB SD memory card.
Thank you.
Regards,
irwannurhadi.
Feb 11, 2009 | Hitachi DZ-MV550 DVD Camcorder
8gb micro sd card does not work. lg vu cu920. is there a fix
I HAD THE SAME PROBLEM AND KEPT ON MESSING WITH THE 4G MEMORY CARD AND FOUND OUT THAT I HAD TO FORMAT THE MEMORY CARD ON MY COMPUTER AND NOW IT READS THE CARD..ON THE SIDE OF THE SD ADAPTER HAS A SLIDING PIECE THAT SAVES YOU FROM DELETING THINGS ACCIDENTALLY BUT IF YOU SLIDE IT INTO THE MIDDLE POSITION THEN IT WILL ALLOW YOU TO FORMAT THE MEMORY CARD BUT YOU WILL LOSE WHATEVER THAT IS ON THE MEMORY CARD AND WILL HAVE TO DOWNLOAD IT ALL OVER AGAIN..I HOPE THIS IS CLEAR ENOUGH FOR EVERYBODY TO UNDERSTAND BUT THIS IS HOW I GOT MY MUSIC AND PICS ON THE MEMORY CARD
Jan 26, 2009 | LG Vu CU920 Cellular Phone
Laptop wont recognize 4 gb sd card
We have 3 of the original 512Mb Disney MixMax players for the kids and, according to the specifications printed on the box, the largest memory card you can use is a 2Gb card, you cannot use a 4Gb memory card with a Mix Max. I have further tested this fact by trying to use a 4Gb card myself and it will not work no matter how I try to format it or anything else. I decided to be smart: read the information they give you with the product and don't try to add a memory card that's too big for the item's capabilities. You have no choice but to buy several 2Gb cards like we did and put them in a carrying case so the kids hopefully won't lose them.
Nov 08, 2008 | Disney Mix Max Digital Media Player
SD card
wahoo!just been rummaging the internet and i have found that these cameras will only take up to a 1gb memory card!so just get a smaller size card
The camera has 16 MB of internal memory. Memory capacity can be expanded with 16MB, 32MB, 64MB, 128MB, 256MB, 512MB up to a maximum of 1 GB SD or MMC cards.
Hope it helps!!!
Jun 23, 2008 | Kodak EasyShare C330 Digital Camera
It doesnt read my SD memory :S
Take it back for a replacement or contact the manufacturer for a warranty replacement.
Mar 28, 2008 | Disney Mix Max Digital Media Player
I bougth a 4GB SDHC card for my 1 GB ilo w/expansion slot, will it work
my new ilo 1gb mp3 player's manual reads: you can use up to a 1 gb sd or mmc card. hope this helps. :)
Nov 30, 2007 | iLO MP3 Player
Polaroid M635 Digital Camera Logo
107 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
