How do I fix fine lines through my tv - Televison & Video
  • 53 Answers
I think you'd better send it to fix,it is a litter dangours!
tablette pc
lecteur ebook
Posted on Feb 22, 2012
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Tv picture is broken into vertical lines
The TV may have blown out. Time for a new one are you can reset you TV. Hope This Helped
Nov 24, 2013 | Philips Magnavox TS3260C 32" TV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
My TV worked fine a few hours ago. Now I have horizontal lines across the screen and I can barely make out what is on TV behind the lines. I did have a brief power outage of about two minutes between the...
It sounds like you had a power surge and there was electrical damage to the TV. Was the tv plugged into a surge Protector? Also if the tv is older the bulb may be going out though this is unlikely to give you horizontal lines. If it was fried, try talking to a local TV/electronics repair shop. they will most likely be able to replace the control board. Best buy and such would also be able to fix but at a greater cost.
May 05, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Our TV has been perfect for many years. We now suddenly have the picture compress, if you will, to the bottom 2/3's of the television screen, and it makes an angle like a triangle going toward the bottom....
This fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around $120, possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it could possibly damage the system.
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Hope this helps!
Mar 08, 2011 | Sony KV-32S42 32" TV
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
