Question about HP Color LaserJet 2600n Printer
Changing toner cartriges
The printer displays shows that I needed to change the black toner and the magenta. After changing them, the display still shows them as needing to be replace.
  • 4 Answers
Check to see if you have removed the shipping strip. This alows the toner to be distributed. Make sure you get the whole thing out or you will have printing problems.
Posted on Oct 28, 2008
Model HL-4040CDN, told me to change magenta toner
Have the same problem, can't find the solution. Filed a complaint on the brother website feedback link, hopefully they will resolve if more people post problems with toner cartridge changes
Nov 10, 2009 | Brother HL-4040CN Laser Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
Hello, I have a Minolta Magicolor 2490 MF, printer/copier. The display shows "low toner". My question is this: Is it possible for the machine to identify the seperate toner levels, so I can replace only...
hi,
if it has a 4 toners which color are separated (the cyan, magenta, yellow and black) then you can replace a low toner one at a time. for example if the black color prompt you that it needs a replacement then you can put off the black toner without changing the other color not until such time it prompt you that it needs replacement. For replacing it I believe it has an instructional manual or if it's still under warranty you can ask assistance from your dealer to help you how.
Dec 20, 2008 | Office Equipment & Supplies
Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Sep 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
How do i change a black cartridge ona Magicolor 2300DL? The black toner is shown as empty but the menu only allows me the options of changing one of the color cartridges. Black is not mentioned
Black is listed as K. CMY (Cyan Magenta Yellow) K (Black)
Easiest way ids to open the fron door, remove the toner bottle and poke a screwdriver in the small round hole near the toner opening. This will free the carousel so you can move it to whatever colour you want to remove.
Sep 04, 2007 | Konica Minolta magicolor 2300DL Laser...
Printer will not print black.
Try removing the magenta completely and shut the lid then open again then insert the new magenta and see if the ink device level on the PC shows full. Sounds like the system needs resetting. Alternatively change the magenta and power on and off the printer and see if this resets it.
Aug 29, 2007 | Brother MFC 420CN All-In-One InkJet...
HP Color LaserJet 2600n Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
