I have this system, but the CD does not work. The display shows the word "checking" and the CD seems to try to read the disk without succes. I can`t eject none of the 5 CD from the tray. Just appears the word CHECKING on the display. Other modules operate normally. Any suggestion?????
I had this same problem on the CDES600. This worked for me
1) Remove the cover off from the unit.
2) Unscrew the 5 cd changer from the back of the unit
3) Look down on the changer and push all the CDs in the unit to the front and remove them.
4) For each of the 5 trays on the front of the cd changer removes the plastic lip on the front of the tray; they about 5x1 inch big and will snap off. (You will cringe but mine did not break) I removed all five.
5) Each tray can be removed by pushing or pulling from the front. You have to really force them and they will make a clicking sound but mine did not break. Make sure all the trays are pushed all the way in. Push hard and they will click in but not break.
6) There is a wheel on the front that moves the CD selector as seen from the left side. If a tray is jammed move the wheel to select different tray and then force the tray jammed tray in.
5) Power it up and see what happens.
I think what is happening is the trays get stuck or a CD gets jammed and the sensors do not work properly. The front 5 lips also get jammed easily causing malfunction. Mine are off permanently
I also noticed when I had it apart that the fan is broken. Anyone know if could use a regular 12v computer fan on it?
It sounds like you have put a disc in the tray that the system can not read, so it will just keep trying to read the disc over and over again. If you turn everything off by the plug and wait a few mins the whole system should stop. Put the plug back in and as soon as you turn your system on, try and press the disc open key before the lens gets a chance to start reading it again.
If this does not work you may just have a disc jammed. So you will have to get someone to check it out for you if you do not understand what you will be doing, because you may do more harm than good to your system.
Ismael, does the solution of Bruce work for you? I got the same problem. I put a CD on the Tray 2, The tray goes in, and nothing else append. I open the door just to see, but know, the disk is on the tray 4 ??? And now, I can`t eject none of the 5 CD from the tray.
Gerard
Was this helpful?
Yes
No
Solution #4
posted on May 01, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
take cover off and make sure the discs are all in position, with mine the top disc was out of position I moved it and the unit worked fine after that..
i have a panasonic stereo that has speakers with red/black and then 2 other ones for bass. i was...
(More)
i have a panasonic stereo that has speakers with red/black and then 2 other ones for bass. i was fiddling with it putting a different set of speakers on it and the bass went. all i have is treble and mid. what could the problem be as i checked the fuse inside and its ok?
i have a sharp xlhp515 and i want to use my verizon fios remote control. verizon does not have sharp...
(More)
i have a sharp xlhp515 and i want to use my verizon fios remote control. verizon does not have sharp on the list under the audio section
one day i was listening to music and i shut it off when i was done and a day later i went to play...
(More)
one day i was listening to music and i shut it off when i was done and a day later i went to play music and it wouldn't turn on and started playing an annoying clicking noise
I bought a Sharp XLMP131 player a couple of years ago as a demo model, on sale. Didn't get a manual...
(More)
I bought a Sharp XLMP131 player a couple of years ago as a demo model, on sale. Didn't get a manual with the unit. Somehow, I have done something with the memory key/feature and now my CDs don't play at all. I was trying to set the unit to play randomly, but would be happy just to get it back playing the CDs individually.
I have unplugged the unit for a couple of hours, hoping it would forget the memory I programmed accidentally, but no luck.
If you can't suggest a solution for the problem I could also use the mailing address or SHARP Company information to send for a manual. Sharp's website address did not come up on google when I started searching today.
happy new year to one and all.
