Question about Nokia 6680 Cellular Phone
How to fix a memory card system error - Nokia 6680 Cellular Phone
    Top Expert:
  • Nokia Master
  • 1,575 Answers
Hi
Check whether the slide lock on the side of the memory card is slide to 'open'.
Try using another memory card.Also,make sure the memory card you're using is supported [not larger in capacity]
Posted on Feb 22, 2012
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
Memory card not formatted operation failed Problem
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted error to learn more about fixing. Regards
Jun 15, 2011 | Computers & Internet
My mobile memory is correpted and im unable to open the files
Dear Sir,
Try fix the corrupted file by scanning your memory card in PC or laptop
Remove your Memory Card from your phone and insert it to Card Reader
when your Memory Card is detected in computer go to my computer and right click on the Memory Card then click properties, click tools and click check now, list for fix system for error, then click ok, wait for the process to finish and then defragment your Memory Card by clicking defragment now..
hope it helps and thank you for visiting FixYa
May 30, 2011 | Computers & Internet
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
System error -20 for my memory card
Hi
The memory card of your phone might need to be formatted,you should remove the memory card and try it with another mobile and if it works fine then it might not be compartible with your phone.
If it doesn't work then you would have to format your phone memory card with a system.Just fix it into the system and click on format.
BEST OF LUCK
Jun 22, 2010 | Nokia 6600
My memory card is corrupted how i can repair
Hi
Memory card corrupt errors occur when ejecting without safely removing
from system or from phone which causes some files delay write fail
Your memory card problem can be solved in many ways
Firstly
1.Insert the memory card in card reader and
in windows xp go to the drive properties of memory card by right clicking the drive and select
the tools TAB and select "Check now" as seen in check errors
and tick both " Automatically fix file system errors" and " scan and recover bad sectors "
click start and it will fix all file system errors
and all your data is safe too
2. another method is format your card. but it will erase all data
hope this will solve your problem
Feb 28, 2010 | Computers & Internet
When i open my camera it says system error and shuts of can you help
I hope it may be a ' lens error'.if it means
u can try this at once..
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Jun 24, 2008 | Cell Phones
PS2 Memory Card Read Error
Have you tried cleaning the open connections?
Apr 08, 2008 | Sony PlayStation 2 (PS2) Console
Error openx menu dat error
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
Mar 30, 2008 | Nintendo DS Lite Console
Nokia 6680 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
