Question about Directv D12-300/100 DTV Receiver
White lines on screen after reconnecting Directv D12-100 Box to TV
I have a Directv D12-100 Box. It was connected to the TV through an old VCR. The VCR no longer works so I disconnected the cable from the VCR and reconnected directly to the TV. I'm getting sound and video reception, but there are white, horizontal, parallel lines showing on the screen and the video picture seems to be sort of washed out. I tried using a different cable to connect the D12-100 box to the TV, but I get the same results. How can this be fixed?
D12-100 box does not have an hdmi port what it does have is a problem the signal level coming out of the box is to high install a 4 way splitter between the box and the tv line out of the box to the in of the splitter any port out of the splitter to the tv the problem you are having is called ghosting
Posted on May 01, 2012
3 Suggested Answers
SOURCE: directv wont turn on
Make sure your internet connection is good, I had a wire go bad and drove us crazy, as a last result I changed it and the DVR came back to life. It needs internet to startup
Posted on Feb 05, 2011
  • 160 Answers
SOURCE: how to hook up a
Hello.
My name is Russ and I will try to help you with your problem.
But first let me explain you something about hooking up equipment to TV.
Several years ago it was very common practice to hook up cable box to the VCR/DVD combo and into TV. Some installers still doing it today. It is easy for installer and only 1 cable is running tovwards TV. Before it was necessity because bunch of direct view TV's had just one input.
This kind of installation have big disadvantages. When video signal runs into TV trough some other device it just getting worse, not better.Quality is reduced and you are getting much noisier and low contrast image than if you would run connection straight into TV.
Today's TV sets have several inputs and able to get direct unmolested signal from several sources such a DVD player, Satellite receiver etc.
You don't need to connect your DVD player to DirecTV box or wise-versa. They actually not even designed for such connections. All you need to do is run most high-quality connections straight into two different TV inputs and enjoy highest quality video and sound possible. You will need to change inputs on your TV screen when changing from Satellite to DVD, but it's OK, everybody does it.
If your DirecTV box have HDMI output, I would recommend use HDMI cable for highest quality possible. Next in line would be component (red, green, blue for video and red, white for audio cable and/or output) Both those connections a high-definition. For standard definition you can use composit (yellow for video, red and white for audio cable and/or output). Last and worst is regular antenna (RF) cable. You need those to run satellite signal from dish to receiver but after that I would recommend not to use it.
You should read your TV owner's manual, it should have diagrams and pictures of everything that I just explained to you.
Regards.
Russ.
Posted on Dec 02, 2010
How to connect HDMI set top box to analogue VCR and then to Digital tv to record
Most set top boxes with HDMI also have a yellow video out and white audio out for connection to a VCR or DVD recorder. Connect these two RCA cables to the VCR's yellow and white INPUTS for recording. Set the VCR to LINE input. For VCR playback, connect yellow video and white audio OUTS from VCR to your TV's yellow and white INPUTS. Select this input on the TV set.
Feb 13, 2012 | Sanyo Televison & Video
Trying to connect a new Samsung Bd-C5500 to my old Sony tv. Can't even get the set-up screen to come up on the TV. All we have is a TV, a Cable box and this new Samsung. We bought it because it is...
That depends on the connections your Sony TV has. If it has only the coaxial connector (the cable looks like this: http://www.w-l-t.org/Pix/Coax%20w-F%20connector.jpg), then you'll connect a VCR to that, and then the blu-ray player to the connections on the VCR using the composite cables (yellow, red, white). Switch the VCR to channel "L" or "Line" (usually below channel 2), and it should pass the video through to the television. Of course, if the TV itself has the yellow, white, and red connectors, you should just be able to connect the Blu-ray directly into that.
Also, it may be possible to connect your cable box as an intermediary like I just described with the VCR, depending on your model of cable box.
Oct 28, 2010 | Samsung BDC5500 Player
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
Have directv what are the connections i need
You should be able to connect direct tv OUT yellow red and white to the IN yellow red and white on your DVD player/VCR combination. Then you connect OUT on your DVD player/VCR combination to the av video input of your television. By yellow red and white I am reffering to composite/RCA cables. There might be a way to connect with component cables though. I would need more information.
Apr 28, 2010 | Televison & Video
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
I have a 27" color flat screen tv by Samsung which I bought from Best Buy in Lakeland, FL 4 yrs ago never had a problem til now. I had a power outage in my home but the tv wasn't on nor was the...
Try to use your directv box with a different A/V connection to the TV and see what happens?
EX. If you have a basic directv box using coaxial cable connection,try to use RCA(yellow,red/white) cable to a RCA input behind the tv.
solutiondoct
Nov 22, 2008 | Televison & Video
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
Directv D12-300/100 DTV Receiver Logo
352 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
