Question about Refrigerators
I have a samsung RF26 series and I need to locate the defroster timer any sugestions?
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
Krazytech
  • 725 Answers
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
SOURCE: maytag fridge defrost timer location
its not a timer , but an adaptive defrost control board, in the upper rigth hand side of refrig compartment, atop the control housing heres the part number 61005988.
check this site ==> http://www.fixya.com/support/t1330051-defrost_timer
Good luck,
Tony Ip
Posted on May 28, 2009
Have Grasslin GM Series 30 amp timer. R1 resistor is burned out. Can you give me the ohm value and wattage for R1 on the pc board.
R1 is probably different for different models of the timer.
Normally if R1 is burned... look carefully and other nearby parts have signs of burning also.
R1 is the first place you see the overheat problem,,, and that's true with the older and newer models in the GM and Woods series timers, including defrost series.
http://waterheatertimer.org/images/Defrost-timer-burned-part.jpg
Contact Intermatic.com and see if they offer a schematic and replacement parts sheet... but I've not seen a parts sheet.
The timer is usually taken out of service and replaced once R1 is burned.
Frequently these timers with burned R1 are sold on ebay after they have been removed from service... simply because the timer looks good or repair seems simple.
Replace timer?
http://waterheatertimer.org/How-to-wire-GM40-timer.html
http://waterheatertimer.org/Intermatic-Defrost-timers-and-manuals.html
Gene
Oct 08, 2014 | Hardware & Accessories
Lrbn20512ww defrost timer location
USUALLY LOCATED IN THE FRIDGE SECTION AT TOP CENTER COVERD BY A PLASTIC PLATE NEXT TO THE COLD CONTROL AND AIR FLOW DAMPER KNOB
Jun 01, 2014 | Samsung RS2630SH Side by Side Refrigerator
How to find
Add comment and describe timer in detail
Paragon 4000 series timer is replaced by Intermatic T100 series:
http://waterheatertimer.org/Buy-T100-series-timers.html
Paragon defrost timers are shown following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Or choose Intermatic defrost timers:
Gene
j
May 16, 2014 | Paragon 4001-0G Defrost Timer
Can't find the defrost timer on my Kenmore refrigerator 596 series
If you get the complete model number which is located inside the refrigerator on a tag either on the upper left or right wall or the roof inside and then go to partselect.com you will get an illustrated blow out and you'll be able to see exactly where every part is
Sep 05, 2012 | Kenmore Refrigerators
Samsung rf26 leaking water inside fridge
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Oct 04, 2011 | Samsung RF266AE (260 cu ft) Refrigerator
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
We have a samsung rf266abbp and the freezer is ultra frosty. this just started this week. the unit is about 1 year old. does it need to be defrosted. if so, how?
Hi, if freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model)
Take care
May 13, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
My Samsung side by side fridge is not cooling properly. The freezer is fine but the refrigerator does not cool enough. I cleaned it recentley but just wiped it down - nothing odd
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Refrigerators
My fridge compartment is warm and not cold but the freezer section works fine. It's Samsung rl39wbms
Check the freezer for frost on its back wall. The refrigerator gets the cold air for cooling from the freezer section. If you have frost on the back wall you have a problem in the defrost circuit. There are three parts involved in the defrost of the coil. Heaters, thermostat or defrost thermostat, and timing device. If your model has a mechanical timer you can located it and rotate the clutch head screw Clockwise very SLOWLY until you hear one click. This puts the freezer into the defrost mode. After 30 minutes if the defrost takes place and the refrigeration does not restart, rotate the clutch head screw a little more and it will start. This tells you the timer is the problem. If it does restart by itself and defrost does not take place your problem is in the heater of defrost termination thermostat. The timer is generally located near the controls for the temperature.
May 31, 2008 | Samsung Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
