Question about SkyScan 34202 Clock Radio
Older, automic clock
Correcting older automatic clock to current Eastern DST
2 Suggested Answers
jrh8879
SOURCE: set correct time for sky scan atomic clock model 87310
How do I reset the time on my atomic clock 8700?
Posted on Feb 08, 2013
Clock face does not show DST. When clock is set to correct time, it turns back one hour at midnight.
DST start and stop was changed a few years back. If you clock has embedded code with the old start and stop, the only way to fix it is to turn off automatic DST. Not sure what clock you are using however it appears to picking up the current GMT time. Another cause is if you have a time zone setting, CST, EST, PST etc.
Mar 20, 2016 | Audio Players & Recorders
Tip
Daylight Saving Time Changes for SmartSet Clock/Radios
Dear Emerson SmartSet® Clock/Clock Radio Owner:
Your Emerson SmartSet® Clock or Clock Radio includes Emerson’s patentedAuto Time Setting System that
automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and
after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and
alarm settings for up to 5 years, or even longer.
As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/
Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into
all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight
Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April
and ends on the last Sunday in October.
The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to
extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in
March and end on the first Sunday in November.
Of course this is a situation that is beyond the control of Emerson, or any other company that produces
devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA’s, and
many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to
make adjustments to the automatic DST software to agree with the new DST timing for 2007.
Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It
would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows:
1.) On the second Sunday in March you would have to set your clock to the next lower number time zone.
For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone
1 to move it ahead by one hour.
2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the
clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set
your clock back to Zone 02.
3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone.
4.) On the first Sunday in November you would again set your clock back to your correct time zone.
Instructions for changing the Time Zone setting are found in the Owner’s Manual.
We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
Printed in China
508-02
on Jun 13, 2009 | Emerson Smartset Clock Radio
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
MODEL:WT-8005 CLOCK IS 1 HOUR AHEAD HOW DO I TURN IT BACK?
Check both of these
  • Daylight Saving Time Automatically Updates (DST) (On/Off Option) applies to both USA and UK
  • U.S. Time Zone Selection: Eastern, Central, Mountain, Pacific (applies to USA only)
  • Mar 15, 2011 | La Crosse Radio Controlled Atomic Clock
    Can't seem to get the correct time ever since daylight savings
    Make sure that the DST switch on the back of your clock is turned ON and that your clock is receiving the WWVB signal (see manual). If the clock is more that two years old it's set to the old DST changeover schedule and that cannot be modified. If it's on the old schedule, your best bet is to turn the DST function OFF and manually change your time zone twice a year. This, however, will probably not solve the problem if you're in the Eastern time zone -- your only option will be a new clock. For an operating manual on a model similar to yours, visit:
    http://www.lacrossetechnology.com/8117/manual.pdf
    Bill B
    Mar 30, 2010 | SkyScan 86709 Atomic Wall Clock
    I can't get my atomic wall clock to set on daylite La cross wall
    The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
    Bill B
    Mar 18, 2010 | La Crosse Radio Controlled Atomic Clock
    Setting timezones on Netvanta 3200 router
    clock auto-correct-dst
    clock timezone -5-Eastern-Time
    clock set 23:58:00 05 May 2010
    Aug 28, 2009 | Adtran NetVanta 3200 Router
    Emerson smart set clocks
    Sorry it took so long to give you a answer to your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day! Dear Emerson SmartSet® Clock/Clock Radio Owner: Your Emerson SmartSet® Clock or Clock Radio includes Emerson?s patentedAuto Time Setting System that automatically sets the clock to the correct year, month, date, day and time, the first time that you plug it in, and after every power interruption. It also includes a built-in long life lithium battery that can maintain the time and alarm settings for up to 5 years, or even longer. As an added benefit we have programmed the internal SmartSet® computer to automatically adjust for Standard/ Daylight Saving Time changes through the year 2097. TheDaylight Saving Time information programmed into all SmartSet® models was based on the United States Uniform TimeAct of 1966, which formalized theDaylight Saving Time period that we observe today. CurrentlyDaylight Saving Time begins on the first Sunday in April and ends on the last Sunday in October. The new Energy Bill that was signed into law by President Bush in August 2005 includes a provision to extend Daylight Saving Time. Beginning in 2007 Daylight Saving Time will begin on the second Sunday in March and end on the first Sunday in November. Of course this is a situation that is beyond the control of Emerson, or any other company that produces devices with an automaticDaylight Saving Time adjustment feature. For example most computers, PDA?s, and many other devices also have automatic DST adjustments. Manufacturers of these devices must now begin to make adjustments to the automatic DST software to agree with the new DST timing for 2007. Beginning in 2007 the current automatic DST default settings in this device would no longer be correct. It would then be necessary for you to manually adjust the TIME ZONE setting 4 times each year as follows: 1.) On the second Sunday in March you would have to set your clock to the next lower number time zone. For example if you lived in the Eastern Time zone (Zone 02) you would then change your clock to Zone 1 to move it ahead by one hour. 2.) On the first Sunday in April, this clock will automatically advance by one hour. You must then set the clock back to your correct time zone. For example if you lived in the Eastern Time zone you would set your clock back to Zone 02. 3.) On the last Sunday in October you would again set your clock to the next lower numbered time zone. 4.) On the first Sunday in November you would again set your clock back to your correct time zone. Instructions for changing the Time Zone setting are found in the Owner?s Manual. We apologize for any inconvenience this may cause due to circumstances that are beyond our control.
    Oct 26, 2008 | Emerson Smartset Clock Radio
    Daylight savings time again
    Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
    Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
    SkyScan 34202 Clock Radio Logo
    Top SkyScan Audio Players & Recorders Experts
    Rick Goldsmith
    Rick Goldsmith
    Level 1 Expert
    Tom Chichester
    Are you a SkyScan Audio Player and Recorder Expert? Answer questions, earn points and help others
