Question about HP Smart Buy- HP Compaq 6710b Notebook PC RM342UTABA410 instant savings PC Notebook
Processing speed is too slow
Booting and processing speed is so slow that it takes almost 5 mins to re-boot. simple tasks like word processing have the machine hanging for long. The laptop was ok until a month or two ago when it just went slow. The storage doesnt have much.
alfi819
  • 65 Answers
SOURCE: while booting hang , only showing f10 boot screen .
Here it is.
1. When asked to press F10, do it! It will take you into bios setup, then load "bios defaults", then "save and exit"
You should also try to update you bios and all your drivers. Come back here for instructions if #1 do not solve your problem.
If you find my solution usefull, please rate it at FixYa.com
Thank you ;)
Posted on Mar 28, 2009
bhagyavichar
  • 414 Answers
SOURCE: My laptop is very slow while booting XP.
i guess ur using a licensed and 'updated' antivirus..
howevr, hv a glance ovr the software strength..look for startup items (the programs loaded during startup)..download n install n run 'Statup Control Panel'..
http://www.pcworld.com/downloads/file/fid,7976-order,4-c,desktop/description.html
and microsoft kb890830..remove the unnecessary boot item(s) or do post me a complete list of startup item that the Startup CPL is showing (in itz every tab), i'll guide u..
also u may use 'Advanced System Care Pro' to fix all at a time..
always better to get supervision frm ur system admin/vendor....
Posted on Oct 28, 2009
big-dog420
  • 124 Answers
SOURCE: Laptop just shutting down every 5 mins or so --
Sounds like the CPU is overheating. Try cleaning with canned air. On the bottem of the laptop you can see a fan with laptop off and battery removed use a whole can of air to clean it. wait 5 min. replace battery and try normal start up. listen for the fan to come on if it doesn't the fan is bad and needs to be replaced
Hope this helps
Please leave feed back
Posted on Nov 29, 2009
Testimonial: "Great help Thank You !! Will try the approach I hope it helps. !!"
benwabnick
  • 2404 Answers
SOURCE: Slow boot time for Windows XP Pro
Turn on your laptop and keep pressing F8 to get to the boot menu. Choose safe mode and let it boot up into safe mode.
After you get into safe mode click on the start button in the bottom left hand corner (or the vista logo). on the run line type in "msconfig" (without the ") and press enter.
It will bring up the system configuration utility, from there click on the startup tab and then click on disable all. Do that and this will make sure none of those programs are loading up when you boot up into windows.
Let the laptop reboot and if you can get into windows without any of theh crazy slowdown then you know its something in that startup tab thta is slowing down the computer, from there you can add back what you need and see if any of what you add back is slowing down the computer.
If you do this and the computer is still very slow in booting up then the windows system files are corrupted and then you would need to go into the system restore and set your laptop back to the last date when it was running properly.
If that fails, then you'll need to save your data and wipe out the driver and reinstall the OS and device drivers.
Posted on Dec 18, 2009
dreamkam
  • 83 Answers
SOURCE: HP COMPAQ NX6110 LAPTOP HANGS WHEN BOOTING
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
Posted on May 28, 2010
When i turn on my lenovo 5000 y500 laptop very slow booting takes place
There are so many reasons can cause a Lenovo computer running slow at boot up, it is hard to identify just what might be dragging down your Lenovo's performance, let alone implement the necessary technical adjustments to fix it.
So if you want to address the issues more easily, I'll recommend you try a Lenovo speed up software, available here: http://www.speeduplenovo.com/
Over 10+ small utilities packed into one to help detect & fix all slowdowns in 1 click.
Aug 04, 2012 | E-Machines eMachines Refurbished EMA...
Slow booting and sudden switch off
The reason may be one or more problems acting together. The problem nowadays is that it is very difficult and time consuming to monitor and take care of your Lenovo laptop. Even experienced users find it hard to perform such tasks on regular basis because you might need to prepare a huge amount of time and energy to deal with each issue separately.
If you want to fix the problems more efficiently, try the Lenovo speed up program. Regards!
Aug 02, 2012 | Lenovo 3000 Y500 7761 Laptop AC Power...
Computer booting up. at least 5 min. or more.
You can use the following link to check , why the computer is giving performance issues.
http://tinyurl.com/29w3pgr
Slow system performace could be caused due to multiple issues . Namely less free space on the hard-drive, too many startup programs, virus or spy ware.
Thanks for using Fixya
Proton
Jul 28, 2010 | Dell Dimension 2400 PC Desktop
The computer is taking too much time to process
Check programs at startup menu. There should be some programs whis downs computer speed after boot
Apr 12, 2010 | Intel Motherboard
Post Boot Freeze
It freezes because one of the programs set to start at boot crashes. To identify which immediately after booting open Task Manager and look at the processes - one should reach 99% CPU use. Once you have found it stop it from launching at boot or just uninstall it.
Jan 22, 2010 | Dell Inspiron 1525 Notebook
I have a Dell Dimension 8250 and when i boot up XP it takes 5 Min to boot up. And on my Task Manager my CPU is alaways at 100%
Hi , bring up your Task Manager again and click on processes.Look for svchost and see how much resources it is using .If it is over 70% then you have likely got a virus,the svchost virus.
Jan 03, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 1525 is very slow causes?
try to check running programs on the back ground, you could view that by going to the task manager.
exiting programs that you dont need will give you some spare virtual memory.
to access task manager:
press ctrl+alt+del then press task manager,
also check the loading programs upon booting the computer, check your startup and remove unnecessary programs that load upon startup.
set your computer to have the best performance
one more thing try to disable your anti virus to see if it is the cause of the slowing of performance.
Sep 12, 2008 | Dell Inspiron 1501 Notebook
Slow speed on booting.
you should try to remove unnecessary files in your hard drive.. afterwards, try to run the disk defragmenter. this tool will help you computer to access files faster thus making your computer load up faster..
Jan 21, 2008 | Acer Veriton 5200D PC Desktop
Slow booting process, "twitchy" mouse movement
Do you have an anti-spyware program on your machine? There are many free programs out there. This might speed up your machine a bit.
Nov 07, 2007 | IBM ThinkPad R52 Notebook
Very slow booting
If you're going to plug-in a video card you need to turn off the onboard video chip. Otherwise It sounds like a cold problem, you could heat areas of the motherboard with a hairdryer to find out..
Oct 18, 2007 | Mach Speed (MSNV-939) Motherboard
HP Smart Buy- HP Compaq 6710b Notebook PC RM342UTABA410 instant savings PC Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
