Question about Garden
There is no spark at the plug
As above
    Sergeant:
    Champion:
  • 320 Answers
If you have no spark at the plug, the coil is most likely the problem. Have it tested at a shop.
Posted on Mar 05, 2012
HOW DO YOU REMOVE THE SPARK PLUG FROM A HUSKEE 26750 TSC ROTOTILLER
repair manual
Huskee 26750TSC Operator Manual
page 14 shows the spark plug
above the stamped OHV metal cover on the motor
plug might be covered with one of these hard plastic caps
they break often and you can buy new ones
or a stock rubber insulated plug connection
would then suggest a tube spanner or plug spanner
Tiller Spark Plug Parts
cant say if its spark plug is a long threaded long headed type
or a stumpy
Oct 17, 2016 | Garden
Spark plug gap for 65 Ford Mustang 289 v-8
.034 gap.
Different spark plug manufacturers may have different spark plug specs?
Oct 07, 2016 | 1965 Ford Mustang
What is the spark plug gap for the above car which is 4 cylinder. thanks
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
Feb 04, 2016 | 1988 Oldsmobile Cutlass Ciera
Change spark plugs
  1. Disconnect the spark plug wire at each spark plug.
    • Twist each spark plug 1/2 turn.
    • Pull only on the boot in order to remove the wire from each spark plug.
  1. Disconnect the spark plug wire from the ignition coil.
    • Twist each spark plug boot 1/2 turn.
    • Pull only on the boot in order to remove the wires from the ignition coil
  • Install the spark plug wires at the ignition coil.
  • Install the spark plug wire to each spark plug.
  • Inspect the wires for proper installation:
  • Repeat above procedure for all 8 cylinders.
  • Jun 17, 2013 | 2003 Hummer H2
    I have 2002 Pontiac Grand Am and I cleaned out the spark plugs and replaced them. The car still only cranks and will not turn over. Any help you provide will be greatly appreciated.
    Possible causes:
    Ignition coil bad
    Electronic ignition module bad
    Coil wire to the ignition module bad
    All of the above.
    Pull out one plug and ground it to the engine. Have someone crank the engine as you watch for a spark. No spark- see above. If there is spark the the problem lies in fuel/air/compression.
    Dec 09, 2010 | 2002 Pontiac Grand Am
    Where are the spark plugs located in the car
    ON TOP OF ENGINE IN CYLINDER HEADS YOUR IGNITION COILS ON TOP OF SPARK PLUGS REMOVE THE ENGINE TOP COVER YOU WILL SEE COIL PACKS ON SPARK PLUGS.YOU NEED A LONG SPARK PLUG SOCKET TO REMOVE SPARK PLUGS.
    Oct 11, 2010 | Kia Spectra Cars & Trucks
    Where are the spark plugs located on a 98 cav 2.4 litre engine
    4cyl. located on top follow spark plug wires to the spark plugs. 6 and 8 cyl. located on the sides just above the intake and exuast ports.
    Apr 17, 2010 | 1998 Chevrolet Cavalier
    How do i change spark plugs on a toyota seqoiua
    You need to remove the coil packs that are located above the valve cover. It is important to get the correct spark plugs from toyota. Aftermarket plugs are not recommended.
    Oct 24, 2009 | 2006 Toyota Sequoia
    THE TRUCK IS HARD TO START SOMETIMES
    Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator.
    Inspect Fuel Injector Cold Start Valve Damaged or Faulty Cold Start Valve.
    Inspect PCV Valve Plugged or Damaged PCV Valve.
    Inspect Spark Plugs Fouled Spark Plugs.
    Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay.
    Inspect Hose (PCV)at Clogged or Collapsed PCV Hoses.
    Inspect EGR Valve Improperly Functioning or Faulty EGR Valve.
    Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
    Inspect Wireset Worn or Damaged Spark Plug Wires.
    Hi, i have listed a cluster of problem spots that you will need to inspect for damage. You will find that your hard starting issue will be the cause of damage in one or more of the above problem areas listed above. Please check each area thoroughly for ware and tare and possible damaged components as well. replace any damaged or worn device listed above.
    Please rate and god bless:)
    May 04, 2009 | 2003 Chevrolet Blazer
    I lost spark to the spark plug!
    There is a magnet on the above the flywheel that creates spark. It is called the armature. This will allow you to get spark as long as your flywheel is good, but this is the most common cause besides electric start system
    Feb 12, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
    Garden Logo
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
