Question about Epson Stylus Pro 9600 InkJet Printer
Epson 9600 Magenta problems...
Hi guys!
I have a problem with my Magenta in my Epson Stylus Pro 9600. I've been away for 3 months and come back to do a nozzle check and found that my nozzles have become clogged up. Carried out a head clean 12 times a power wash twice and the nozzle check results show that all colors seem fine now apart from the Magenta... I've wasted plenty of ink on trying to fix the problem but I'm pulling my hair out on what to do!?!? Since I called up Epson they have told me my warrenty is over and that the problem seems to be with the whole head part... which is costing me a lot (ouch).
Anyone know what I can do?
Help me please... :(
  • 1 more comment
  • Fase K
    Fase K Oct 27, 2008
    ...and before anyone asks, I have replaced my Magenta cartridge. (I am using Ultra Color Chrome Ink)
  • Johnd3445 Nov 18, 2008
    I have the exact same problem.... No clue what to do...
  • geek22 Jan 07, 2009
    I have the same problem, I've taken a paper towel with windex to it, many many head cleanings.....magenta just wont work!! Help!
  • 16 Answers
Sounds like a problem with the damper/cleaning unit.
You need to clean the "pads" under where the print head parks.
Turn off power. open front cover. push it cutter (blue) and slide printhead to the left.
You will see a pad in there. this is the cleaning area. Remove and clean. Also next to this is a wiper. it is vertical and needs to be washed with some rubbing alcohol.
try these and get back to me.
Posted on Jul 12, 2009
Ink streaks on print epson 9600
The problem solved by "switching off" the Digital Signature.
Since the driver from Epson was safe it was allright and safe to do that...
Apr 02, 2013 | Epson Stylus Pro 9600 InkJet Printer
" Set Ink Cartridge "
Did you try disconnecting from the power for a few hours to reset the printer? Also, did you try a waste tank reset?
Mar 26, 2008 | Epson Stylus Pro 9600 InkJet Printer
Cartridge stuck in epson 9600
Probably dried ink has it stuck in the carrier. Try using an eyedropper and dripping some alcohol along the edges, and repeat periodically several times to let it soak in and loosen the ink, overnight should do it, then try again to press the release tab and wiggle the cartridge firmly until it lifts out.
Apr 29, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Apr 23, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 vs Agfa Sherpa44
The Agfa Sherpa is not manufactured by Epson. Both Epson and Agfa buy and retag their printers from Mutoh.
I do not know if the 44 is the same as Epson 7600 or 9600, but it should fit the same cartridges.
If the printer does not accept the cartridges, that means that there is something different in the software stored in the Epson cartridge chip.
In this case you will be only able to use only Agfa or Mutoh Falcon cartridges.
Oct 27, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
938 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
