Question about WYSE S10 (90210501) Network Terminal
Dns/wins can't resolve wyseftp
Server 2008 r2
Unable to install windows 2008 r2
too old hardware ?, more memory or harddrive size
Apr 09, 2014 | Dell PowerEdge 1800 Server
Tip
Getting Blue Screen on Dell laptop with Win Server 2008 R2
I talked to a Dell rep yesterday and was telling him that my new Dell laptop (in my case an E6510) allowed me to load Windows Server 2008 R2 but I kept getting the Blue Screen of Death (BSOD) every so often. He said it was the drivers for the chipset and that I should just upgrade them to the latest. He also said the Win 7 drivers for other components work fine because the two operating systems share a common code base. If you are installing Win Server just have the drivers, particularly the ones for the network adapters, handy on a flash drive, extra partition or CD when you do the server install.
on May 28, 2010 | Computers & Internet
Polaroid PMP 120-4 driver
THere are drivers for Windows Server 2008, Windows Home Server, Win 64-bit, Windows Server 2003, Windows Vista, Win Server 2003, Win Me, Windows XP, Win Server 2008 R2, Windows 98, Windows 98 SE
I'm not sure if theres is a drivers for Win 7 or Win 8 so if you don't have one you should install Windows Vista or XP driver using compatibility mode
Dec 06, 2013 | Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital...
How to use the rupees symbol in logitech k200 keyboard
you may download Rupee.rtf file from internet..Place it in Start> Control Panel > Fonts....When u open an editor like MS Word...for rupee symbol select "Rupee" from font drop-down and for typing it use the key just above the tab key on ur keyboard. You are done.
Nov 16, 2011 | Logitech 967437-0403 Keyboard
Thank you for the last one. know i want to set up mu 3laptops on the windows server 2008 r2 standered and use the server as a domain and the laptops as well like a domain.
first you need to setup the roles in the server, go to the manage server console, ( can be found as a shortcut in the taskbar or under start menu ) then open the console and go to add roles.
1 - add active directory
2 - in the process it will ask you to install the DNS server role ( do it )
3 - after installing the role in the CMD command prompt type DCPROMO
4 - the DC controller installation and setup will beging ( do not do anything during this proccess )
5 - when asked by DC setup to choose what type of domain functionality level do the following
1 - windows 2003 ( this is for compatibility for windows server running 2003 and XP machines )
2 - Windows Server 2008 ( at this point nothing lower than XP can be added to the DC of course domain functionalities will increase - Only other 2008 server domain controller can be added and cluster migration from server 2003 to 2008 is not supported. )
3 - Windows Server 2008 R2 ( at this point only machines running Vista and 7 can be added to domain - windows xp is no longer supported. All the functionalities of the domain controller are available)
keep in mind once you promote the domain controller to a higher level it can't be brouht to a lower level.
once active directory is installed restart you server and the you should be able to add the clients pc or laptos to the DC example
- right click over my computer icon
- click on properties
- computer name
- change the computer from workgroup to domain
- type your FQDN ( fully qualified domain name) example: mynetwork.local or mysite.com
- apply changes and restart
- your computer will be part of the domain next time system boots up.
Mar 01, 2011 | Computers & Internet
I need win 7 32 bit driver. Using win 2008 r2 as print server.
You have to install 64 bit drivers on server 2008 r2, share the the printer. It will load properly when you connect to it from a Win7 client
Sep 13, 2010 | Sharp MX-2700N Color Copier
Server 2008 Email Notifications Setup
If you don't have an email server on your network then you would need to set that server up as an SMTP server. You would need to install that role via Roles and Features through Server Manager. There are additional steps you would need to take...Once you install the Simple Mail Transfer Protocol role - (SMTP) You need to configure the settings on your server for DNS. I'm not sure what type of DNS setup you have but you would need to know how to setup your mail server in DNS so that it is resolvable on your network as well as through your ISP.
Sep 28, 2017 | Microsoft Windows Server 2008 Enterprise...
I have tried x2 chassis and working memory but cannot get the full 12gb installed and runniing with Win 2008R2. it only takes x4 2GB sticks. Have tested all sticks in other machines and in same one...
Please see the below table to find you are on the right track.
Windows Server 2008 R2 Datacenter 2 TB
Windows Server 2008 R2 Enterprise 2 TB
Windows Server 2008 R2 for Itanium-Based Systems 2 TB
Windows Server 2008 R2 Foundation 8 GB
Windows Server 2008 R2 Standard 32 GB
Windows HPC Server 2008 R2 128 GB
Windows Web Server 2008 R2 32 GB
Feb 17, 2010 | HP Compaq ProLiant DL380 G4 Server
Win server 2003 enterprise
You need to ensure your DNS server is the first in the workstation's DNS list.
Does this help?
Sep 27, 2007 | Microsoft Windows Server Standard 2003 for...
WYSE S10 (90210501) Network Terminal Logo
1,160 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Tim Hunt
Tim Hunt
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
