Sin conexion cuando enciendo mi camara aparece una figura que dice ´´SIN CONEXION yno acepta ninguna otra funcion necesito ayuda.
svenby
  • 66 Answers
SOURCE: editha malet
mp145
Posted on May 30, 2008
dj_relly999
  • 4070 Answers
SOURCE: cuando quiero tomar una foto
Hi! Can you please tell me more bout the history of the problem. Thanks!
Posted on Oct 06, 2010
puertobori
  • 7733 Answers
SOURCE: Hola como etas soy Liz,
Issue When the printer comes up with an error code on the front panel, we may have to perform the service test(s) related to the error code. Sometimes when we enter into service/diagnostic mode and try to perform a test, the printer may come up with system error 79:04 (non-continuable generic error). When this occurs in diagnostic mode, it is not likely possible to analyze it by pressing front panel keys (e.g., up arrow and cancel); the printer will likely be hung/stuck with the error. Solution To overcome this issue, ensure that no data cable is connected to the printer (Network/USB/Fire Wire). For proper use of the diagnostic menu, the printer should be in a stand-alone state (only connected to power). Once it is confirmed that the printer is in stand-alone mode, then enter back into service/diagnostic mode and perform the test(s) required.
Posted on Dec 15, 2010
  • 628 Answers
SOURCE: Como puedo instalar la impresora
Obtain the software from www.hp.com/support.
Posted on Feb 26, 2011
puertobori
  • 7733 Answers
SOURCE: Como puedo anadir una clave
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Apr 29, 2011
Hola, mi camara no dispara correctamente, al presionar el disparador se traba y aparece un rotulo en la pantalla que dice presione nuevamente y luego termina la foto, las fotos son de buena calidad... pero...
Cuando esto sucede en mi Nikon D-90, recibo un mensaje "ERR" en el panel de control. Nunca he conseguido un mensaje "vuelva a intentarlo". Sin embargo, suponiendo que esto es el mismo fallo, el manual del usuario dice que esto es un fallo de c?mara que puede ser aclarado por liberaci?n del obturador. En mi D-90 s?lo puedo hacerlo girando la c?mara y otra vez. A veces, tengo que quitar y volver a colocar la bater?a. El manual dice que si este problema persiste, debe enviarla a un centro de servicio autorizado de Nikon. Si lo que he sugerido que el problema no soluciona, sugiero que contactas Nikon support en www.Nikon.com para ver lo que proponen.
Dec 01, 2012 | Nikon D60 Digital Camera
Sin conexion
tengo el mismo problema pero no encuentro solucion
Feb 22, 2012 | Computers & Internet
Mi video camara es canon Dc210 DVDcamcoder no acepta los DVD que le pongo de ninguna que puedo hacer
El manual dice que algunos discos no vas a funcionar con la cámara, pero por supuesto no hay nada en el sitio de eso.
Yo sabía acerca de un problema similar, ya que estaba tratando con los discos DVD + RW. He encontrado algo la solución en la web de Canon: DVD-R/RW y DVD + R / RW son similares, pero en general los formatos no interchangable.
Las videocámaras Canon DVD sólo utilice discos DVD-R/RW. DVD-R/RW y DVD + R / RW son similares, pero en general, los formatos no interchangable. Las videocámaras Canon DVD sólo uso * DVD-R/RW o DVD-R DL (DC10, DC20, DC100, DC40 y no son compatibles con discos DVD-R DL). Si un disco DVD + R / RW se carga en una videocámara Canon DVD de la videocámara mostrará un mensaje "Error de Disco" después de que intenta leer el disco.
* Discos DVD-R de doble cara también se puede utilizar sin embargo, cada lado deberá ser inicializado antes de su uso.
Espero que esto le sea de ayuda; recuerde calificar esta repuesta. Suerte.
Sep 26, 2011 | Canon DC210 DVD Camcorder
Enciende y aparece reinicie camara error de objetivo
tengo problema con mi camara...!!
la enciendo y m sale error de objetivo reiniciar camara... la camara se apagara autmaticameente
Aug 30, 2011 | Canon PowerShot A495 Digital Camera
NO APARECE MI CAMARA WEB QUE VIENE INCORPORADA A LA LAP, COMO LE HAGO, DICE QUE NO SE ENCUENTRA O QUE ESTA OCUPADA O QUE NO TENGO, QUE DEBO COMPRAR UNA Y ESO NO ES POSIBLE, POR QUE SI TENGO CAMARA WEB,...
que hago tenia instalado en mi pc oficce 2003lo cambie por 2010 pero cuando quiero reproducir una presentacion de power poit dice que no se encuentra el punto de entrada del procedimiento except handler 4 common en la biblioteca de vinculos dinamicoas de msvcrt.dl que devo de hacer por favor quien me puede ayudar
Feb 24, 2011 | Computers & Internet
La Alarma de mi Sebring 98 se desconfiguro de Cuando le remplase Las Pilas Como La sincronizo o Como Hago Que funcione Otra Vez o desavtivarla por completo
Trata de cerrar el carro las ventanas manual mente sin el control the botones y luego cuando este todo cerreado cierre con la llave del lado del chofer y espere un minuto y luego abra con la llave sin el control the botones trate eso suerte.
Aug 11, 2010 | 1998 Chrysler Sebring
NECESITO CONFIGURAR MI CAMARA EN LA COMPUTADORA Y NO PUEDO....
pero tienes el cd?, de todas maneras yo estaba de vacaciones y deje el cd en mi casa, pero conecte la camara al computador de un amigo y las vaje de una vez, sin habere instalado el software(CD), luego cuando llegue aqui a mi casa instale el cd y el programa se llama arcsfot photoimpresion 6, despues tuve problemas para ver el video que habia hecho, pero tuve instalar quicktime, bueno si alguien puede dar mas informacion, a mi me gustaria saber mucho mas de la camara, porque me aparecen iconos como un avioncito, una rueda, tambien tome una foto y tiene sonido, si alguien sabe todas las funciones que no estan en el manual mi correo es indytu@hotmail.com clocas ref.camara
gracias
indira
Jan 12, 2009 | General Electric A835 Digital Camera
24 people viewed this question
jasbo
jasbo
