I want to install a second hard drive in my HP dv7-4180us what do I need
I want to install a second hard drive in my HP, what do I need to install it besides the mounting case from HP and cable. but where does it hook up and what are the part numbers
melnavz
  • 1226 Answers
SOURCE: how to install second internal hard drive
Yes, you can use, Please see label attached to the harddrive for a jumper setting to become primary harddrive.
in the DVD rom there's also a label on it. but the most common setting is slave is in the center.
C S M -
c-cable select
s-Slave
M- Master
the jumper is set to center to become a slave.
the hard drive is should be a master
connecting to the other end of the IDE cable.
HDD-should be a master
DVD rom-Should be a slave
Hope this help.
Posted on Feb 20, 2008
kevin000
  • 1847 Answers
SOURCE: adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
Posted on Sep 01, 2008
SOURCE: Finding it difficult to install a second hard drive on hp dc7700
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10226&cs_id=1022602&p_id=4863&seq=1&format=2
Posted on Jan 16, 2009
efs_perpends
  • 1996 Answers
SOURCE: computer doesn't see new secondary hard drive
I'll assume you're using windows xp, but in any case have you tried going to my computer>manage>disk management to see if it appears? If not, refer to pg 8 or pg 14 of this article to Install a hard drive. You may have to enter the bios (F1 at boot) to allow the new drive. Also see this link to your bios setup screens.
If you're still having problems after looking through this info and checking the bios setup, write back and we'll be happy to help sort it out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 13, 2009
  • 272 Answers
SOURCE: Okay! Now I have a problem. On the SR2180NX (along
If you can not find any, keep it on the floor of the case ;)
i had same problem, now , one of my hdd is not hooked on anything. Well, there can be found a cd-rom like HDD case, it should be found on any computer selle shops.
Posted on Oct 09, 2009
How to install second hard drive in HP P7 1107c
  • Stick the HDD into an available slot in the chasis
  • Connect an available sata power cable from your PSU to the HDD
  • Connect a sata data cable from the drive to an available sata port on the motherboard
  • Close the case and power on the computer
  • Right click My Computer/Computer and select "Manage"
  • Go to Disk Management and locate the drive (Disk 1) most likely
  • Right Click it and select "Format" choose your partition type and format.
  • Create one or more partitions.
Jul 13, 2012 | HP Computers & Internet
02-07 Fail HP Pavilion dv9000 Installed a brand new hard drive, Same error.
get all your information you need off of the HD and reinstall windows see if that will get rid of the problem.
Dec 13, 2011 | Computers & Internet
Whenever I start my HP laptop, a black screen loads and it says " Boot device not found, please install an operating system on your hard disk". I have no clue how to fix this.
Sounds like the hard drive has been formatted and you need to install windows on it. Was it working before or did you just buy it second hand?
Jan 29, 2011 | HEWLETT-PACKARD HP G72251NR NOTEBOOK PC...
What do i need to install a WD Scorpio Blue 500Gb hard drive in my HP dv90052us laptop - i've got the drive but it does not fit in it's slot like the original drive does - i'm putting it in the second...
You may need a "caddy" -- a metal shell that wraps around the disk-drive, in order to line-up its "data" and "power" connectors with the matching "sockets" inside the second drive-bay.
Order the caddy from http://support.hp.com
Apr 18, 2010 | HP Pavilion dv9005us Notebook
HP a6412p added 2nd hard drive but wont work get blue screen
you should try switching the sata port you plug your new drive into. also, you should go into your BIOS setup f2 and save setting then exit.
Jan 25, 2010 | HP Computers & Internet
Want to add 2nd cdrom
In order to burn from CD to CD you don’t need a second CD-ROM. Nero will save the CD image on the hard drive and then will ask you to put a blank CD and record the image from the hard drive to the CD.
To install a second CD-ROM use the same bus to the hard drive and set the jumper to “slave”. Good luck.
Sep 15, 2009 | HP Computers & Internet
Installed HP C6380 and lost 2 of my hard drives
Try the drives in another usb port set, for example at the back or the front of the computer in a diffrent set of plugs than where the printer is.
May 22, 2009 | HP Photosmart C6380 All-In-One InkJet...
HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Mar 29, 2009 | HP Media Center m7250n (ED842AA) PC...
some older sytems don't have the option to add a second hard drive
can you save your files on cd's or travel drive and then install the new hard drive
Jan 16, 2009 | HP RT810UTABA - HP dc7700 small form...
How to install a second DVD writer in an m8300f
for first dvd drive you have to put master jumper and for second you out slave then both drives work
Mar 21, 2008 | HP RT917UTABA - HP Promo dx2300 micro...
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
