Question about Remington Electric Chain Saw
Remington 16 in. electric chain saw
Took the white housing off to clean, and lost the bolts to put back on. Also cant find my old maual. Can parts/manual be sent?
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Posted on Oct 31, 2008
I have a Remington 16"
most any bar and chain oil for chain saws will work. The cheaper the better just make sure you keep the chain oiled up. if you can touch the chain and oil oil does'nt get on you you not using enoght and put oil right on the chain. certainly when you put the saw away to store it. even wrapping the bar and chain in a rag with oil in it is a good idea as it'll be ready for next time.
Jan 31, 2011 | Remington 16" Electric Chain Saw Assembled...
My remington 16 inch electric chain saw is not oiling, how do i fix it?
Start by making sure it's unplugged. Then remove chain, and bar, and clean oil slot in the bar and all of the housing in the area the oil comes out onto the bar. I use carb cleaner (safer than gas) and then empty and clean the oil reserve. Refill with straight 30 weight. Never use car oil like a 10w30 or 5W40! Then prime (pump) and start the saw without chain or bar. You should see some oil squirt out. If not, soak a clean empty oil reserve overnight in carb cleaner and try again.Once the oil path is clean, you should be back in business. If not - see your authorized service center.....LOL
Jun 17, 2010 | Remington 16" Electric Chain Saw Assembled...
Can't get chain to tighten
Hello Ted:
This is a very good OM for a Remington. Look at figure 8 on page 8. The adjustment block MUST engage one of the holes in the bar, Then do 1 through 5 as illustrated and you cannot go wrong.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If the block is engaged, the bar nuts are finger tight , and the adjuster will not tighten the chain it must be stripped. If not stripped, follow this example.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If it still causing problems try a local saw shop where someone can see what the problem is. Ask them to demonstrate please.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 07, 2010 | Remington 16" Electric Chain Saw
Lost manual need to know what kind/weight oil does the Remington 16" chain saw require?
Any good quality chain saw 'bar' oil is suitable and it does not need to be an expensve brand either: it is highly recommended that you use a specially blended chain saw 'bar' oil but in emergency you can you fresh 'thick' (e.g. older) car engine oil but don't make it a habit as your chain and bar will wear off a lot faster!
Mar 06, 2010 | Remington 16" Electric Chain Saw Assembled...
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
The chain came off of my Remington 16" electric saw. How do I put the chain back on?
If the saw was at speed when the chain came off there are probably burrs on the chain drive links (the part that goes in the bar). They often cause binding and in extreme case may cause the chain to ride up and off the bar when operated. Use a file on the drive link flats to remove all burrs.
An Operator Manual far almost all models of RemingtonPower chainsaws can be found here:
Remington.com
HTH
Lou
Dec 28, 2009 | Remington 16" Electric Chain Saw
What type of oil is used in electric chiansaw
The oil to use for the chain is called BAR OIL and if there is anything that might be universal, it is BAR OIL. You can use BAR OIL on electric and non electric saws alike. Self sharpening and non-self shaprening chains. Any manufacturer. It is BAR OIL.
Do not use any other kind of oil in your saw. BAR OIL is particularly sticky and hangs on to the chain even while cutting the wood at high speed.
Thank you for posting your question at FixYa.com
Please remember to vote
a
Nov 11, 2009 | Remington 16" Electric Chain Saw
Replacing Remington Electric chain saw blade
Where the bar meets the body of the saw there is an adjustment lug that will either push the bar outward tightening the chain or may be retracted allowing slack in the chain. When backed off (loosened) sufficiently, the chain may be removed for replacement. In order to use this feature, however, there are two bolts that secure the bar to the body that must be loosened prior to any adjustment and tightened bach up after making adjustments to the chain. The above will be enough to remove and replae the chain. If you are taking off the bar (that the chain runs on), you will need to remove the two bolts that were just loosened for the chain adjustment (above).
Regards! --WoobieDog--
Jul 07, 2009 | Remington 16" Electric Chain Saw Assembled...
Replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
Mar 31, 2009 | Remington Electric Chain Saw
Remington Electric Chain Saw  Logo
369 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
