Question about Brother HL 5250DN Laser Printer
How to reset tn-620 toner cartridge - Brother HL 5250DN Laser Printer
  • 13 Answers
SOURCE: New toner cartridge and paper jam
Does this happen when you install the old toner? Is the NEW toner an OEM or compatible? I have run into this problem before on some other Brother all in one models. There is a sensor flag located just below the toner and drum unit. Remove the toner/drum unit, check that the sensor flag will move to back and forth freely. My customer removed the toner and drum unit and threw the drum unit away, not realizing that the toner seats into the drum unit. When they placed just the toner into the printer, it read paper jam. Because the drum unit is part of the paper path, the sensor was not in the correct position.
Try re-seating the toner into the drum unit and then re-seat the entire unit into the printer. Let me know if this helps.
Posted on Oct 20, 2008
komguy
  • 2306 Answers
SOURCE: REPLACING A CARTRIDGE
you take the toner and drum assembly out of the printer, set it on a level surface, press the blue lever on the left side rear, and lift and remove the toner. Remove any packing material from the new cartridge, set the front toward the drum in first and lower the rear down until the blue lever clicks. Re-install the assembly into the printer...good to go!
Posted on Sep 15, 2009
  • 526 Answers
SOURCE: i have a brother 2140
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
Posted on Dec 31, 2009
  • 15 Answers
SOURCE: I bought a new toner
please reset toner using reset software or printed paper count reset
Posted on Oct 01, 2010
ross_lovegro
SOURCE: Brother MCF-7340 first time toner replacement
If it is your first toner replacement you shsould only need the TN-360, as the drum should be good for about 12,000 copies. The machine will tell you when you are getting close to replaceing drum unit.
Posted on Oct 13, 2010
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
Uneven color printing...magenta only on sides of photo...not in the middle
Definitely a faulty cartridge. It is probably a build up of toner on the doctor blade or a deformed doctor blade.
Nov 14, 2017 | Brother HL-4070CDW Printer
Hello sir my brother tn-3250 laser toner blinking yellow light
Toner Blinking yellow LED indicates that the toner cartridge is nearly empty. Buy a new toner cartridge or refill the cartridge. Refilling the TN cartridges is quite simple and you can do it yourself.
It is a very simple process. Please refer to this video.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 17, 2011 | Brother HL-5250dnt Laser Printer
Can not find out how to change ink cartridge on a tn 350
tn 350 is a toner cartridge, you pull the toner and drum out together, set on a table, press the blue lever on the side of the holder and lift out the toner. Remove all packing and insert the toner front edge first into the holder and then snap down the rear edge. Re insert into the printer and close the front door...
Feb 13, 2010 | Office Equipment & Supplies
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
Change drum
You need to go buy a Brother DR-350 drum unit cartridge. The drum unit is the thing that the toner cartridge (TN-350) clicks into. Pull out the drum/toner unit and separate the two halves. Place your TN-350 into the new DR-350 cartridge and put back in the printer.
Jan 18, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Brother HL 5250DN Laser Printer Logo
899 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
