Question about George Foreman G5 Indoor Grill
Broken lock on grill plate
My grill has grill plates that can be changed. One of the locking handles is broken. Can I get a new handle or a replacement grill?
  • 1 more comment
  • GnanaB Dec 19, 2007
    Where can i find replacement grills??? Food now sticks to both sides and makes a mess and handle broken also.
  • auctionsunli Feb 12, 2009
    broken locking handle on forman g5 grille
  • Anonymous Mar 17, 2014
    I have a 30 yr old Jenn-Air grill which has two rock plates at the bottom. How do I effectively clean these? I have used a wire brush and soap and water over the years but still has build up
I was able to google and find someone selling a replacement grill plate on ebay. Also, Amazon sells some replacement grill plates, but not the waffle one I was looking for.
Posted on Dec 17, 2007
I found out you can buy parts online o george foreman.com
                   GOOD Luck
                     Chriss Agel
Posted on Oct 25, 2007
If you find a source for a replacement locking handle, we would appreciate you letting us know. Likewise, we will let you know if we find a source. Thanks, utxfamily@aol.com
Posted on Jan 14, 2007
Outside handle is loose on Schlage entry lock
Remove the inner handle and cover plate, tighten the 2 screws under the plate. Re-assemble.
Dec 21, 2013 | Schlage Hardware & Accessories
How do I remove the water filter to replace it?
If you have a side by side, the water filter is normally located on the front grill at the bottom, also known as a kick plate. You will see a circular area with a handle that is flush with the grill. Simply turn the handle and the filter will pull out. Slide the handle off the old filter and onto the new and insert back in and twist to lock in place.
Dec 08, 2010 | Whirlpool Refrigerators
I need to replace the door handle on my '96 honda civic, how do i get it off?
Pop off the speaker grill and remove the three screws securing the panel to the door frame. You do not have to remove the screws holding the speaker to the panel. Remove the window crank. There is a "U" shaped retaining spring holding the handle to the spindle. It can be removed with a special tool or just by pressing in on the panel and loosening the clip with a small flat blade screwdriver. Remove the screws in the arm rest and above the interior door handle lever.
Pull the panel from the door - be careful of the speaker wires - carefully undo the quick connect.
From the top corner, pull down on the plastic sheet.
Remove the square white plastic box that is used as a guide for the control bars.
Locate the exterior handle mechanism. There are 2 10mm bolts that hold the handle to the door frame. Remove them with a ratchet and extension.
Pop the retaining clip (it's green for the left door) free from the lock cylinder control rod, then pull the rod from the back of the lock cylinder.
Covering the back of the lock cylinder is a metal plate. Holding the plate to the cylinder is another "U" shaped spring clip that can be pulled down with a flat blade screwdriver.
After removing this clip, the metal plate will seperate from the cylinder. The culinder can then be pulled free from the inside and the handle from the outside.
Reverse the procedure to reinstall.
Its possible that need check the Honda-Civic-1996-1998-Service-Manual-Part-III
Hope help with this (remember comment and rated this post).
Apr 21, 2010 | 1996 Honda Civic
My 2004 Toyota Sequoia rear door will not open - the handle is broken. How do I get into the door, whith it closed, to make the necessary repairs?
Dig out the broken bits of door handle, then on the right side insert a flat head screwdriver diagonally up and fish around for the release lever.
Push up on the screwdriver handle to manipulate the release lever down and your tailgate will open.
Remove the interior panels by unbolting the 10mm bolt behind the strap and pulling off the interior pieces held on by plastic pop fasteners.
Remove the 10mm bolts around the perimeter of the interior cover plate and let it hang by the harness.
Remove the license plate.
Remove the license plate trim panel (multiple push fasteners from behind and a few 10mm around the lock)
Replace the handle.
Sep 13, 2009 | 2004 Toyota Sequoia
My handle on the lower grill detachable plate GRP99 GF grill is broken. Can I get a replacement handle for it?
Where can I find a replacement part for my george foreman GRP90WGR model , I dropped one of the grill plates and the handle broke need replacement part.
Aug 05, 2009 | Kitchen Appliances - Others
Power door lock switch replacement
Remove or Disconnect
Door handle trim plate.
  1. .Install or Connect
  2. Electrical connector and door lock cable.
  3. Trim panel by engaging hooks on backside of panel.
  4. Push pin fastener in defroster duct.
  5. Screw from behind lamp assembly.
  6. Courtesy lamp assembly.
  7. Two screws in arm rest.
  8. Arm rest cover plate.
  9. Door handle trim plate.
There May Be A Need to Drill Out RIVETS that Hold Motor in place,. Just Replace with>>MACHINED SCREWS & BOLT'S
  1. Trim panel. See: Doors, Hood and Trunk\Doors
  2. Four tabs retaining switch.
  3. Electrical connector.
Install or Connect
  1. Electrical connector.
  2. Snap switch into trim panel.
  3. Trim panel.
Mar 14, 2009 | 2000 Buick Park Avenue
Needing new handles for the removable plates on my George Foreman GRP4.
Hi beccagc06,
I'd contact the manufacturer (Salton, Inc.) customer service site for parts or manual. If they don't have them, they should know where to send you (though if they don't, I'd seriously wonder about the company).
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Sep 28, 2008 | George Foreman GRP4P Indoor Grill
Handles fell off
I have a Foreman GRP99 that has a broken Grill Plate Handle.
I called 1-800-233-9054, Fox-International, and ordered a new handle for $14.95 including Shipping.
Maybe they have support advice?
Dave in Ohio
Apr 07, 2008 | George Foreman GRP99 Indoor Grill
G5 Handles on plates
called salton and ordered new handles for the plates
Mar 26, 2008 | George Foreman G5 Indoor Grill
Foreman Grill
contact these guys; http://www.esalton.com/control/contactus they usually help. here is the link for the manual if you need it; http://www.esalton.com/static/manuals/GRP90WG.pdf Hope this helps :)
Nov 07, 2006 | George Foreman G5 Indoor Grill
George Foreman G5 Indoor Grill Logo
817 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
