Question about Canon Pixma iP4500 InkJet Printer
My Pixma IP 4500 doesn't turn on
Printed one page and when I went ot print the next page, got a window that said 'Printer Offline' Pushed the on button and nothing happened. Checked the cords and still nothing happened.
pagebor
  • 2785 Answers
SOURCE: service error in canon pixma ip 1200??
plz try by reinstalling the printer drivers
Posted on Jun 20, 2008
SOURCE: Newly installed Canon Pixma 4500
HI
I phoned Canon who told me to return the machine from whence it came!!
Posted on Sep 10, 2008
there this orange light blinking and says it full
Posted on Oct 07, 2008
michael_grey
  • 365 Answers
SOURCE: ink absorber full
You can probably do this once as the ink absorber will start to expel in onto the place where printer is on.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Posted on Jun 20, 2009
ihavsolution
  • 152 Answers
SOURCE: Canon PIXMA1500 prints blank pages
you need to change the print head ...
Posted on Jul 15, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
How do i find info on duplex printing on a canon pixma 4500
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
May 03, 2012 | Xerox Phaser 4500/B / Phaser 4500/YB Laser...
HP 1312 printer running wirelessly from a laptop (Windows 7). Has always worked fine. Turned printer off when we were on vacation; now printer is "offline." Have reinstalled printer driver and...
Hi!
The problem you described can have multiple causes.
But one is more common:
Every device on your home network (wired or wireless) has its own IP adress. Usualy this IP adress is given automatically by the DHCP server contained in your wireless router. When a device is turned off for some time, it can receive when turned on again another IP adress than before.
So, if your printer has no static IP adress (entered by yourself during printer setup), it is very likely that it has now other IP than the address known by your computer. The computer sends the print jobs to the old adress and of course, nothing is printed.
Please check in your printers proprieties the adress of the TCPIP port assigned tom it, and also check on your router's management site what clients are connected to it.
The network communication between the computer and the printer can be checked by issuing a PING command from a command prompt.
e.g ping 192.168.1.***
the numbers are one example of an IP adress.
Please let me know if it helped, if you need more help ask again, I'll be glad to help you to get the problem solved.
Regards,
Bogdan
Aug 21, 2011 | Office Equipment & Supplies
I have just installed a Canon MX870 and it won't print - it keeps on saying the printer is offline... I have successfully established a wireless connection and when I go to printer and fax preferences (on...
I had the same problem and just fixed it by opening the Canon IJ Network Utilities and using the tool menu. It turned out that the printer had changed ports and the port was not compatible. That meant that the port it was using didn't have a printer driver associated with it so it couldn't work. As soon as I went into the configure menu and had it try the next IP port, it immediately printed. It's a matter of finding the correct port again or associate the driver the port you are now using.
Jan 04, 2011 | Canon PIXMA MX870 Wireless Office...
How to switch from "offline" status to "online" status
I was also facing the same Problem, I solved it by following these steps
First I noted down the IP address from the Printer, Menu > Network > Wlan > Tcp/IP
then on my pc
1.Point to Printers and faxes 2.add new printer 3.a welcome window appeared click next --select local printer attached to this computer do not check automatically detect............. then click "Next" 4. Point to Create a New port then select HP Tcp/IP Port 5. a Welcome page appears again click Next 6. Now is the time to Write the IP address you noted earlier from the Printer also check Always print to this.......... 7. now by clicking ok or Next it will take some time to load another window 8. Now at the bottom left of this window you will find two options i selected the "custom" option, another window appeared click ok and wait for few seconds, when that disappear click Next Click finish and wait.......... 9. Here You go another window appeared Point to the Manufacturer Brother and then select the model MFC6490 10.Click Next and Point to KEEP THE EXISTING.......... or whatever option you like.. Now its easy follow the on screen steps untill you are asked to PRINT A TEST PAGE
NOW YOU ARE CONNECTED AND ONLINE AND ENJOY....
BUT HAY THE OTHER DAY I FOUND THE SAME PROBLEM "YOUR PRINTER IS OFFLINE" DON'T WORRY, i SOLVED THAT TOO 1--GET TO PRINTERS AND FAXES 2--SELECT THE PRINTER WHICH IS ALREADY INSTALLED AND SAYING " OFFLINE " 3--RIGHT CLICK AND POINT TO "USE PRINT ONLINE" THERE YOU ON FLY AGAIN!!!!!!!!!!!
THANKS MUHAMMAD IMTIAZ KHAN
Apr 02, 2009 | Brother MFC 6490CW InkJet Printer
Printer is offline
go in control pannel> printer> right click on your printer there was option use printer online click on it
Jan 17, 2009 | HP Deskjet 3915 InkJet Printer
Brother HL-2170W Laser Printer is 'offline" wont turn back online
I have a lap top and was having the "printer offline" problem
1) I did the triple click on the printer as in soluyion two to get the IP address which is clearly labled on the 3rd page.
2) Clicked on "Devices and Printers" in the "Start" menu
3) Right clicked the "Brother..." icon and selected "Remove Device"
4) Selected "Add Printer" on the "Devices and Printers" menu
5) Selected "Add a wireless, network, or bluetooth printer"
Nothing was coming up in the search so...
6) Selected "The printer I want isn't listed"
7) Selected "Add a printer using TCP/IP address or host name"
8) Entered the IP adress from the 3rd page of the printout on to the line "Host name or IP address"
9) Left the "Query..." box selected, clicked "next" and printer installed
Jan 04, 2009 | Brother HL-2170W Laser Printer
Service error in canon pixma ip 1200??
Hello,My problem its Pixma IP 1200 for Windows Vista PLZ Help!!!
Jun 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma iP4500 InkJet Printer Logo
158 people viewed this question
old marine
old marine
