Question about GE ZV750SY Kitchen Hood
BULBS I NEED 4 SOCKETS WHERE CAN I GET THEM
  • 10,865 Answers
Take one of them to an electrical supply house and they will assist you.
Posted on Feb 10, 2009
Were is the fuse for the right blinker in a 2003 gmc envoy
Hey Derrick,
I do not think the blinkers have a "right" and "left" fuse...Its usually a flasher/blinker relay.
Try replacing the bulbs.. make sure their sockets are clean and able to hold the bulbs tight. If you are not getting both right side blinkers to work and you know both bulbs are good, the switch in the column may be the culprit.
2003 GMC ENVOY 4 2L L6 Turn Signal Switch RockAuto
Turn signal/Flasher
2003 GMC ENVOY 4 2L L6 Flasher RockAuto
Bulbs/Sockets
http://www.rockauto.com/en/catalog/gmc,2003,envoy,4.2l+l6,1415269,electrical-bulb+&+socket,turn+signal+lamp+bulb,13675
Sep 24, 2017 | GMC Cars & Trucks
Brake lights dont turn on toyota rav 4, whats the problem?
Check the switch on the break peddle , thay can work loose or renewal good luck colin
Jul 05, 2017 | Toyota Cars & Trucks
Changing backup bulbs on 2005 buick rendevous
TAIL LAMP ASSEMBLY AND /OR BACKUP, SIDEMARKER, STOP, TURN SIGNAL BULB REPLACEMENT
REMOVAL PROCEDURE
1. Open the liftgate.
2. Remove the screws from the tail amp.
3. Slide the tail lamp rearward in order to disengage it from the retainers on the rear body panel.
4. Disconnect the electrical connector from the tail lamp wiring harness.
5. Remove the tail lamp and side marker lamp sockets from the tail lamp, depressing the locking tab and turning counterclockwise.
6. Remove the bulbs from the tail lamp and the side marker lamp sockets, if replacing the bulbs.
INSTALLATION PROCEDURE
1. Install the bulbs to the tail lamp and side marker lamp sockets, if removed.
2. Install the tail lamp and side marker lamp sockets to the tail lamp, turning clockwise until the locking tab is fully seated.
3. Connect the tail lamp electrical connector to the wiring harness.
4. Position the tail lamp retainer slots to the tabs on the rear body panel.
5. Install the tail lamp to the rear body panel, pressing into place until fully seated.
6. Install the tail lamp screws to the Taillamp.
NOTE: Refer to Fastener Notice in Service Precautions.
Tighten the tail lamp screws to 2 N.m (18 lb in).
7. Close the liftgate.
Apr 16, 2017 | Buick Cars & Trucks
How do you change the tail lights in a 2011 Durango?
There are a whole bunch of lights in the back. To change the lights under the "trunk" lid you need to remove the inside panel at the bottom (there is no need to remove the whole panel unless you intend to change the middle brake lights). Then, the sockets are exposed and the bulbs can be pulled after 1/4 turn counterclockwise on their sockets. The outer bulbs are accessable from the inside lower side panels being removed and the same about the sockets...
Jan 22, 2013 | Vehicle Parts & Accessories
My left side of the dashboard light went out. How do I fix it
you need to find proper bulb type to replace burned one. in general you need t10 or t5 type bulbs.
before removing dashboard, you need to remove battery cable from (-) terminal.
removal of dashboards differ from car model to car model. basically there are upper screws and you need to remove dash board bezel/trims first.if you remove bezel and screws, there will be several screws holding dash board in its place. try no to drop screws when removing them. and be gentle while moving the dashboard. there are two or three sockets at back. you may need to remove them by releasing their clips. and you will see bulb holders holding bulbs in dashboard in general 4 or 5 bulbs are used to illuminate gauges. remove them by turning covers and put new bulbs in it. intallation is the reverse order. do not forget to clip sockets back.
Nov 20, 2011 | Cars & Trucks
2003 crv headlight warning signal no longer works
You will need to take the instrument cluster out to get to the bulb. The sockets should twist 1/4 turn counterclockwise and pull straight out. The bulbs just unplug and plug into the sockets.
Jun 28, 2011 | 2003 Honda CR-V
Dash lights have burned out
If all of the lights are out, check your fuses and/or instrument dimmer switch. If you have only 1 or 2 lights out, you will need to remove the instrument cluster to be able to access the bulb sockets on the back. The sockets generally come out with a 1/4 turn counter clockwise and the bulbs just plug into the sockets.
Jun 26, 2011 | Pontiac Sunfire Cars & Trucks
My honda accord 2001 is having brake light issues. 3 of the 4 "lower" brake lights will not work and the dash board light is on. The trunk lid lights are working fine. When I put the bulbs from...
Some bulbs are dual function and others are single function. You may be installing the wrong type bulbs in the sockets. Look in the sockets and see if there are two contacts at the base, or a single contact. You can look at the base of the bulbs and see if they have two solder connectors or a single on. Sounds like you need to recheck all your brake sockets to be sure.
May 16, 2011 | 2001 Honda Accord
How to change break lights
Tail Lights
  1. Open the endgate or liftgate.
  2. Remove the screws that retain the tail lamp assembly to the vehicle.
    Tail lamp assembly removal
  3. Rotate the bulb sockets 1/4turn counter-clockwise in order to remove the bulb sockets from the tail lamp assembly.
  4. Remove the bulbs from the sockets.
To install:
  1. Install the bulbs into the sockets.
  2. Install the bulb sockets to the tail lamp assembly by rotating the sockets1/4 turn clockwise.
  3. Install the tail lamp assembly to the vehicle.
  4. Install the screws that retain the tail lamp assembly to the vehicle. Tighten the screws to 17 inch lbs. (1.9 Nm).
Oct 23, 2010 | 2000 Oldsmobile Bravada
GE ZV750SY Kitchen Hood Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
