I have a 43" hatachi
I have a 43" hatachi projection screen had the hour glass look replaced the STK (2) IC'S and hour glass went away but my blue wont move over to red and green only in the middle of screen. Had a repair man come out and told me the same thing i already did and could be the STK IC'S or is there something else to check?
  • chris662 Oct 27, 2008
    what sould the voltage be on the stk's?
  • 10,594 Answers
First replace STKs and if problem still there, check supply voltage of STKs.
Let me know the results to provide you more help.
Posted on Oct 27, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Oct 27, 2008
    Please mention model number of Hitachi 43" TV
    I need to know model number of your Hitachi tv to see its manual and tell you voltages.
    Here you can see picture of STK circuit and its voltage supply at pins. its portion of Hitachi projection tv service manual and just to give an idea because...
    I still don't know what model is your Hitachi TV.
Double image, red is 2 inches off main image. convergance ic amp?
Yes, your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Feb 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
The picture on my rear projection tv has an hour glass appearence. Both side of the picture are curved inward towards the center of the screen.
Hi , i will suspect your convergence board is defective you have 2 ic call stk for convergence correction and pin cushion
and some low value resistor and different bad soldering ,all this needs to be replaced and then reajust ,you must have a digital
array button on the front panel button some an automatic set up call majic focus wheres you must be able to realing this but if you dont have this button is probably locate on the convergence board anyway the circuit needs to fix befor any attempt to make any adjustement ,you may need a tech to do it, ic cost about 20 box each theres two on the board and s its an hour jobs about , depend on the tech experience...
hope that will help
regards Alan
Nov 01, 2010 | Toshiba 57H81 57" Rear Projection...
The picture is bowed and you can see double and the color is wrong
convergence ic stk----- you can repair this yourself if you can solder you can obtain ic.s from matt electronics or any electronic suppliers locate the convergence ic.s on chasis there will be 2 the number will start with stk- most likely stk-392-110 hope this helps
Oct 10, 2010 | Hitachi 43F300 43" Rear Projection...
TV has a picture but it looks like a 3D screen..Clors are out of wack and double text.
stk ics are bad on convergence module also check resistors when you replace ic.s
Feb 03, 2010 | Hitachi 43UWX10B 43" Rear Projection...
42 inch Hatachie Ultravision model 43UWX10B and
The magic focus will stop if there is a bad sensor and or a problem in the convergence circuit.
This set uses two STK-392-110 convergence chips--both along with any of the resistors that protect them need to be replaced and the set adjusted--I have repaired hundreds of these sets----
Confirm model number----and if you go into the customer menu and either red or blue will not move in any or some direction--the chips have to be replaced---LET ME KNOW WHAT YOU FIND AND I CAN GIVE YOU FAIRLY DETAILED INSTRUCTIONS ON WHERE TO GET THE PARTS AND WHAT IS INVOLVED IN THIS REPAIR.
I am here to help people--
REGARDS, SD TECH
Oct 10, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Jan 14, 2009 | Apex Digital GB4308 43" Rear Projection...
Convergence IC's
Stk 394-160 are the better IC and they are available in the DP15H Upgrade kit at the following link.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Convergence
i have tried this replacement on philips 43 inch. convergence ic part # is STK-392-120. it is mounted on a big heatsink, replace this 2 IC at one time. soldering is not difficult. 1. you need desoldering tool (**** type) 2. soldering iron of 40W 3. and silicon grease for greater transfer between IC body and heatsink. i bought that personally in asia for less than 50USD on two IC with same part # . let me know if there is any other thing i can do.
Apr 02, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Convergence
you can replace IC stk 392-110 (one or all) and tray to adjust R_G_B
Nov 25, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
