Question about Philips DECT VOIP-321 cordless telephone
Dialling from computer then taking call on phone?
With my last skype phone I could dial from my skype contact list on the computer and then pick up the handset to take the call while it was connecting. Is it possible to do the same thing with this phone? Seem to have tried everything!
  • 1 more comment
  • elledee Nov 05, 2008
    hi I have this same problem so to dial a random number I have to first enter it into the contacts list. Hope someone has managed to resolve this.
  • Anonymous Mar 04, 2009
    Same, one can not dial from the phone. Need to use from list or dial using the Skype keys. And......found out Philips not longer will make this. And.......its doesn't work with the new (4.0) version of Skype.(Philips 3211g/37
  • zappawo Mar 08, 2009
    Thank you Fred42. I have done a search for the GE phone and it does not come up with anything. Is GE the make of phone or what? I wouls like to order one on line if possible.
    Thanx for yo help
    Wendy
  • 26 Answers
Hi zappawo, This is impossible with the Philips VOIP321. A design flaw. You have to live with it or buy another one, like the GE/Thomson GE21878. I bought the GE with this question in mind. The GE does take over the calls from the screen to the handset. As it should be.
Best regards, Fred
fred.altmann@gmail.com
Posted on Mar 08, 2009
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
My Nokia c2-00 shows "Contacts not ready" message after I turned it on. I can't see received calls, missed calls, dialled calls & contacts list. I can make a dial call, but I can't get receive...
i have faced the same problem in my Nokia c2-00 and i did the following and problem solved.
1. switch off the mobile.
2. Remove the battery.
3. Remove the sim cards & memory card from the slots and reinsert it one by one.
4. restart the mobile. Now i can view the contacts and msg's in my phone..!!
Mar 29, 2012 | Nokia mobile C2-00 Dual SIMbiosis
I am having problem on finding and setting voice tag for contacts.
GOTO CONTACTS
EDIT CONTACTS
EITHER IT WILL BE THERE AS IN OPTIONS
OR IT WILL BE THERE IN SETTINGS
Feb 05, 2011 | Nokia 6720 Classic Cell Phone
Some buttons wont work eg contacts list and dialing button and earpiece is damaged
I have similar problem with Contacts List and Dialing Button, it is a firmware issue, set your Home Screen Theme to Contacts Bar and you would be able to access contact list at least, however the Dialling Button would still not work
You can check if your phone is suitable for V40 firmware upgrade thorugh Nokia PC Suite
Mar 22, 2010 | Nokia 5800 XpressMusic Smartphone
My dialer and contacts wont open on front screen can anyone help?
Mar 14, 2010 | Nokia 5800 XpressMusic Smartphone
Can't make calls with Linksys CIT2000. My Skype is fine but the phone won't connect.
I unistalled Linksys CIT200 (twice), left Skype running, reinstalled it again, TO THE LETTER, but I skipped the reg. section completely. Turned the phone off (at the on/off switch on the phone itself) before, and only turned it on again when the CD was done. Everything came up daisies for me. Got rid of "EAccessviolation" prob, and the "disconnected" prob. To make sure you're up and running, open Skype, dial a number (I dialled my home phone) using the Skype number pad, when you see it's ringing, press the green button on your phone, the phone should take over, and connect you in the process.... If at first....
Dec 28, 2009 | Computers & Internet
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
Incompatibility with ACER computers?
Hi, I have the same phone, I also have an ACER laptop and running vista home premium.
I needed to download the vista software package from telephonesonline (it costs for the download) but no problems after that it works great.
http://www.telephonesonline.com.au/cordless-wireless/Philips/Skype-321/Windows_VISTA-Download/Setup-user-manuals/call-for-free-philips-voip-321-skype-dect-cordless-dual-pack-phone.html
The only thing with this particular phone is that if you have a monthly account (skype pro) and you use your package as your regular phone you need to add every phone number you call to your contact list.
I haven't found a soloution to dial out from the phone using skype with out it being in the contacts list.
Nov 21, 2008 | Philips DECT VOIP-321 cordless telephone
Use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
Sep 25, 2008 | Philips DECT VOIP-321 cordless telephone
Philips DECT VOIP-321 cordless telephone Logo
133 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
