Question about Hilti Drills
I have a hilti te54 that hilti says is too old to repair, where can I go?
The chuck on my TE54 will no longer willing accept or release any bits. When I took it to hilti, they said it was too old to repair and would I like to buy a TE60 for $999. It's just the chuck that's broken, is there anyone else that repairs older hilti tools in Chicagoland?
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
Gigatech
  • 259 Answers
SOURCE: dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Posted on Mar 05, 2008
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
meleemore
  • 19 Answers
SOURCE: Makita Percussion Drill HP2051F keyless chuck release problem
jacobs come out with this all metal keyless chuck(i think thats what you have) and if thats the case, there is no solution for this youll have to replace the hole chuck, being its new, it may be under warrenty
Posted on May 05, 2009
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Posted on Oct 11, 2009
How do you remove a stuck bit in the chuck of a TE 17 Hilti hammer drill?
Hilti TE56 SDS max stuck chisel remove - YouTube
? 7:10
https://www.youtube.com/watch?v=rmpvYuEvbIk
Jun 22, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel in Hilti demolition hammer. Same can be made for ...
Hilti SFC 22 A chuck removal and Makita chuck replacement - YouTube
? 7:12
https://www.youtube.com/watch?v=gkjBs0f0upg
Sep 15, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how I removed Hilti SFC 22 A cordlessdrill chuck. I replaced genuine Hilti ...
Hilti TE76 stuck chisel remove and repair - YouTube
? 12:53
https://www.youtube.com/watch?v=v3ckL1lQ-2E&vl=cs
Nov 26, 2017 - Uploaded by Power tools fix
Hello, In this video you will see how to remove stuck chisel for Hilti Te76 demolition hammer. Same can be ...
How to disassemble and find problem in for Hilti TE 7 C rotary hammer ...
? 17:45
https://www.youtube.com/watch?v=4yY97AAHPO4 Feb 7, 2017 - Uploaded by Power tools fix
In this video you will see how to find problem in Hilti rotary hammer drill TE 7 C -~-~~-~~~-~~-~- Please ...
remove stuck bit in the chuck of TE 17 Hilti Google Search
Jun 12, 2018 | Hilti Drills
How do you remove the drill bit on a Hilti TE 804
It is a quick release chuck, grip the body and twist the chuck anti-clockwise.
Apr 17, 2016 | Hilti Drills
How to Replace Hilti TE22 chuck
You put the two flat sides on the end of the cap nut and lock them in a vice. You then put a wrench on the back side of the chuck which also has two flat sides. with the cap nut locked in a vise take the wrench and turn the retaining sleeve which has the two flat sides counterclockwise to break the cap nut loose. When it turns freely take the chuck out of the vise and turn the cap nut off. You then push the ribbed locking sleeve down to access an o-ring. You pull that off and it releases the locking sleeve and two roller bearings. You then pull off the retaining slv with the two flat sides and release the other two roller bearings. the chuck will then just pull off the shaft
Hope this helps
Sep 30, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How does the chuck go on
You grasp the chuck with the bit end in the palm of your hand, With your fingers pull back the plastic sleeve on the other end. slide the chuck on the shaft. Release the sleeve and turn the chuck until you feel it lock into place.
Aug 28, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
I have an old hilti, model: te 12 s. it wont drill. when i press the botten it only hammers. i have tryed to open the machine but i can not find the problem.
IT could be one of two problems. 1 The Rollers are missing out of the chuck so that it is not turning the bit. 2 the clutch is worn out causing the gears to slip. The problem is there are no longer parts available for the 12S. You would have to find them on Ebay or some place like that.
If the bit seems to lock into the chuck then it is not the rollers. It is more than likely the clutch.
Aug 08, 2010 | Hilti 375847 TE-CX 3/4" x 12" Masonry...
How to disassemble a te 60 , the chuck end. Its not worth sending to factory but i might tackle it myself it does not hammer all the time and does not rotate all the time
Hilti no longer services the old TE60. If yours is a metal housing here is how you disassenble the front end.First you need to put a flat bladed chisel in the chuck. Then lock the chisel in a vise. Next you put a pipe wrench on the chuck cap nut. That is the piece on the end of the chuck. Using a cheater bar turn the nut off counter clock wise. You then can remove your chisel, the cap nut, an oring and the locking sleeve with two rollers. This will expose the chuck that is held in place with 8 5mm allen screws. After that you have a large snap ring to remove before pulling out the rest of the front end assy.
Jul 18, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
The chuck on my old Hilti TE 60 is stripped.
Are you talking about the cap nut that threads onto the chuck? It is very rare that it would strip out. Word of warning if you do find one and thread it back on. You need to have a chisel in the chuck and have the chisel end locked in a vise. This protects from breaking the gear housing on the inside where the shift dog rides up and down.
Those parts are no longer available but you can still find some used on Ebay. Also the TE-72 used the same chuck parts.
Apr 27, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Drills Logo
918 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
