Question about Skil Saws
I need blades for the skil model 87
I need a 9" blade with the diamode shape knockout
  • 302 Answers
SOURCE: I have a very old Skil circular saw Model #586.
measure from the center of the shaft to the inside of the guard, double that distance. subtract about 3/4 of an inch and this will be real close to the blade diameter that you need
Posted on Aug 17, 2009
brewerstool
  • 141 Answers
SOURCE: I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Posted on Oct 13, 2009
digritz
  • 530 Answers
SOURCE: no inner washer to keep blade in place
I really wish I could give you a link to somewhere you could find your part but I have checked all the ones I know and it's a pretty big list. I came up empty. I just don't see a way for you to get a replacement for that saw.
However many saws have the same or similar parts. You need to measure the shaft diameter and head to a hardware to check what ever saw you can for a replacement.
Worst case scenario is to take your saw to a small local machine shop. Find the oldest guy in the place and explain your problem. Buy him a cup of coffee and he'll make you one for practically nothing.
Hey it worked on my boss every time.
I hope this helps.
Posted on Nov 29, 2009
  • 142 Answers
SOURCE: Promblems with the Skil Saw 5750, the bolt that
try using a ratchet instead of the provided wrench. Also, use a screwdriver to help hold the blade from turning
Posted on Mar 26, 2010
awcforever
  • 359 Answers
SOURCE: how to replace saw blade on skil saw
On the side of the saw in the center of the blade, there should be a bolt to remove that will get the blade off. Some saws have a special wrench needed to remove it, but since you have a Skil, you should be able to use either a 1/2" or 9/16" wrench or socket to take it loose and switch the blade out for one of your choice. Hope that helps.
Posted on Oct 09, 2010
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
Need to know how to put blade in
Just pull up on that rectangle shaped black piece on the top of the blade. Then pull the blade out. You can use both type blades in this model. take care and good luck.
Mar 08, 2011 | Skil 468004 5 Amp Jig Saw Kit with Laser
It's actually a Skil model 4280 sabre saw. Problem is it doesn't grip blades properly, so they are constantly slipping out. Chuck seems to be engaged, have shot WD-40 in it - no change. Ideas?
There is nothing wrong with your Skil 4280. The universal U chuck blade is the problem. Look at Lenox blade 4318JC or Disston 5418 and you will see a slight ridge on the face of the blade on both sides where the teeth start and the blade tail engages the chuck. Without the ridge the blade will come out.
Oct 05, 2010 | Bosch Skil No.4280 - 01Variable Speed Jig...
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I do not know how to install blade and have no manual
Most of the skil jigsaws have a plastic piece with a spring and catch behind it. Just push your blade into the tool and it should lock. When you want to remove it you need to press the plastic lock collar up and it will release the blade. Some of the earlier models weren't as easy to set the blade in and you have to press the lock collar up insert the blade and let the collar down around the blade to lock it.
Sep 09, 2009 | Skil Saws
Skil saw motor runs but blade won't spin
you have a loose nut.  Let me explain...the nut and washer that holds the blade to the motor has worked loose.  You need to remove the plate around the blade to acess it and on the end of the blade is a large nut.  Tighten it with the power off.  Sometime there is a grove on the motor shaft to hold the motor or sometimes you need to put a screwdriver into the teeth of the blade to hold in place to tighten.
Apr 04, 2009 | Skil 10" Table Saw
Bought model 3400 skil table saw. have no manual. can't find control for tilting blade. how do i tilt blade
This model does not have a knob on the side.
There is only a locking lever on the front next to a single rotating wheel for height adjustments. To tilt the blade simply twist the locking lever to the left and push the height adjustment wheel to the right. It can be a bit stiff at times to move.
Feb 26, 2009 | Skil 10" Table Saw 3400
Saws Logo
123 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
