Question about Mitsubishi WD62627 62" HDTV
Need to know how to replace WD 62627 ballast - Mitsubishi WD62627 62" HDTV
2 Suggested Answers
SOURCE: i need simple instructions on how to replace the
Minor point, the correct term is 'ballast' like on a fluorescent lamp.
Unplug the unit from the wall.
Remove the filter cover (from the rear, it's on the right side of the electronics cover). Remove the electronics cover (the one on the back with the fan in the center). Remove the rear metal plate (about 25 screws). Remove the right rear support bracket to gain access to the ballast area. Remove the ballast shield. Unplug the two connectors on the ballast module. Unscrew the lamp connector (2 screws). Remove the 2 screws holding the ballast in place, they're at the closer end, near the fan. Lift the closer end of the ballast board and remove (there's a hooked lip holding the other end, no screws).
Posted on Jun 17, 2009
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
I need manual for mitsubishi dlp tv 62 inch model wd-62627
Owner manual or service manual?
Try to Google the model number for either or visit the Mitsubishi site for the owner manual.
May 21, 2012 | Mitsubishi Televison & Video
Model WD 62627 When I plug it in all that comes on is the timer green light at the bottom of the tv.
Replace the lamp of your tv or check it first if damage, feel free to send feed back good day and best regards.
Aug 22, 2011 | Mitsubishi Televison & Video
My tv is mitsubishi dlp wd 62627. has sound but no picture. may be the lamp??? or may be the video card???
I go more with the lamp, if it was the video card, your picture would be completely green or blue, but since what you have is the lack of image it's most probable your lamp is the one defective. You should also be aware that the lamps is powered by other components, if fixing the lamp does not solve your problem, you might have a faulty ballast, which is the board in charge of sending all the energy to the lamp so it can light up. http://www.discount-merchant.com/SearchResults.asp?Search=mitsubishi+lamps/?Click=48427
Nov 06, 2009 | JVC AV-48WP30 48" Rear Projection...
WD-62627 dark pic, contr. and bright. @ full..newer bulb.
You could try to INITIALIZE the tv by doing the following:
1) turn on TV
2) from the remote press MENU 2,4,7,0 then ENTER
3) TV will state that is INIATIALIZING
4) press the RESET BUTTON on front of TV.
5) hopefully it's fixed.
Sep 20, 2009 | Mitsubishi WD62627 62" HDTV
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62627 HD - Replaced lamp & now display is crooked
The lamp is not placed in the housing in the correct position ( try slight adjustment on lamp wing-nut this must be done with your hands
this should fix ya
Dec 11, 2008 | Mitsubishi WD62627 62" HDTV
Mitsubishi DLP WD-62627 Shutting Down
I was going to say that sounds like the power side to me mate the board power board check it out before you spend any money make sure it's unplugged before you do any thing and where a earth strap ok to stop you getter a shock ok
Jul 10, 2017 | Televison & Video
Have two Mitsubishi WD-62627 HDTV's. One will go all black and white after unit has been on a while; shutting it off and turning it back on will correct problem for a while. The second WD-62627 has seven...
The first one sounds like one of two bad boards. If you get color here always(component input (Y Pr Pb) then it's the terminal 2 PCB, and if not it could be FMT board. Either way you would need further checks to make sure. For the other set i would need email for instructions, because of broad range of problems!
Mar 12, 2008 | Televison & Video
Mitsubishi WD62627 62" HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
