Question about Miele G880 Dishwasher
Intake drain light on dishwasher and water not draining.
I have a miele dishwasher and I was running the regular cycle and the intake drain light came on. I turned off the dishwasher and took everything out and cleaned the basket, etc. I put everything back together and tried to run it again, it work for a few moments and then the light came on. The dishwasher is full of water in the bottom and not draining. We have tried plunging and draino. Nothing is working.
Thanks
  • Anonymous Feb 12, 2009
    I have two miele dishwashers and this seems to be a generic problem with them. The Tech Support tried to "walk me through the problem" however it is IMPOSSIBLE to open the valve. Needless to say, we have to get the machine serviced and pay to have it cleaned.
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I have the same dishwasher and it will not INTAKE water. This unit does ****. So much for a "smart dishwasher".
Posted on Apr 07, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
SOURCE: Miele blinking intake drain light
Hi All,
Thx for all the tips. Combining your thoughts provided a solution for me.
I had the same problem (with a ***** of thanksgiving dishes to do). Turn on,
tries to drain, then that RED blinking "INTAKE/DRAIN" light, like you described.
Spent hours, checking/clearing the (grey) drain hose (The other white hose is the water input to the dishwasher). Also took out metal filter, impeller cover, poked a coat hanger in both ways to/from the drain hose connection. All seemed clear. But still the same.
But when I unhooked the grey drain hose from the air gap unit (that part going to the 4th hole in the sink surface), the dishwasher worked fine. So the air gap unit seemed plugged. The black hose from the garbage disposal to the air gap unit is free flowing (blew through it - yuch!). But the drain connection through the air gap unit was NOT as free flowing.
Replaced it with a new air gap unit ($5.00 at Home depot).
All works fine now. I feel I got lucky.
Well this worked for me. Sorry for all of you who spent big bucks with no solution on those service guys that tried but did not help. I hope this helps some of you.
John
Posted on Nov 29, 2008
  • 236 Answers
SOURCE: Intake Drain light on and water in the bottom of the dishwasher
sounds like the flood mode is in operation, you may have a leak into the base stopping the wash continuing. pump out the water, then tip the unit at about 45 degrees and see if any water pours out of the base- confirming a leak.
Posted on Jan 03, 2010
  • 177 Answers
SOURCE: Miele Intake/Drain light on/flashing and the
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage.
Hope this helps.
Posted on Jan 25, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Intake/drain light on
Please check the INLET water pressure, remove the inlet and check. Now if there is pressure make sure that when the power is pressed there is a pre wash cycle to start the machine. If not there is fault in the program controller , please check the door switch and the panel board.
Jan 02, 2013 | Miele Optima G2470SCVi Built-in Dishwasher
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Miele Dishwasher G892SCU Plus Intake/Drain light keep flashing
Hello RD,
Every Miele dishwasher is designed to drain water in the first 30 seconds of any cycle. Does your intake/drain light come on at all? Miele technical services can troubleshoot the fault code if you do get an intake/drain light.
The most common issue I have seen is that the dishwasher drain line is clogged.
Solution - Try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not I would contact Miele technical support to troubleshoot the fault code
Good luck
Sep 08, 2009 | Miele G892SC SS Dishwasher
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Mieli water-intake light comming on?
I think it's regular salt, yes, but I've never bothered to fill mine.
Have you had a dishwasher previously? If not, check the tap where your washer gets its water to make sure it has proper water preasure. If the washer doesn't get enough water it will stop.
In my kitchen there is a separate little knob on the tap to control the water to the dishwasher. this has to be open. Mine has hot and cold selection, but only cold is connected so if I turn it on hot the washer gets no water
Nov 07, 2007 | Dishwashers
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Sep 15, 2007 | Miele 23 in. Novotronic G841 Built-In...
Miele G880 Dishwasher Logo
97 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
