Question about Garden
I have a mcculloch SE2014S and replaced rotted fuel lines is the main fulel and primer fuel the same feed line?
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch 3200 chainsaw on which I
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Posted on Oct 13, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
dontbother10
  • 2220 Answers
SOURCE: McCulloch 3216 fuel primer and gas tubes routing?
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Posted on Nov 01, 2009
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
I have a McCulloch 3516 and am replacing the rotted fuel lines. I've read descriptions of the routing but do not know which is the input and output sides of the carburator or which is the suction side of...
Most primers have two conections on the back the longer one is the pressure side and the shorter one the suction side, the two conections on the carb are fuel in ( nearest to the pump side of the carb, cover made of alloy and usually held with a single screw ) the other is fuel out this is nearest to the metering side of the carb, usually a chrome plated cover held with four screws.
Apr 14, 2011 | McCulloch Garden
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I'm trying to replace the fuel lines on the primer button of a small McCullough chain saw. The old ones had dry-rotted and fell off, and I couldn't determine which line goes where. My first configuration...
The primer is just a small pump--it is supposed to draw fresh fuel through the carburetor and expel it back into the tank. There are also just two lines on the carburetor--the upper one should go straight to the fuel tank and filter, the other goes to the intake side of the pump. Just pick a port of the primer (remove the other line for the moment), and try to pump fuel into the bulb (make sure the bulb is not decayed as well)--it should fill with fuel if you have the correct connection--if not, just place the line from the carburetor on the other primer port and try to pump again. If still no fuel, something is plugged in the carburetor or the fuel filter. Hope this helps!
Nov 10, 2010 | McCulloch 16" Electric Chain Saw 35 HP
Will start on prime, but will not continue to run
Lines are reversed. Filter feeds carb (probably lower fitting). Carb feeds primer. primer feeds tank. Primer removes air from carb. does not inject fuel into carb throat. HTH Lou
Feb 19, 2010 | McCulloch Garden
I have a McCulloch 3200 chainsaw on which I installed a new primer bulb and fuel lines. The old fuel lines were broken. I figured out which line runs to the carb from the primer bulb but where does the...
Lou
Oct 08, 2009 | McCulloch Garden
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Change feed fuel feed line craftsman string trimmer
no should be fairly straight forward! you can find the tubing at ace lowes home depot! good luck & happy trimming!!
May 31, 2009 | Craftsman 25cc Gas Line Trimmer
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
