Question about Sharp Office Equipment & Supplies
Error code:C4-02 Hi, I have a Sharp MX-4101N and it keeps coming up with the error code:C4-02 what does this mean?
SOURCE: Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
P, * , CA , P then enter sim # 14 to reset code.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Posted on Dec 11, 2008
  • 990 Answers
SOURCE: What does the error code F2-40 mean on a Sharp MX-M4501N?
according the manual F2-04 means drum data read problem,may be it can be reset why don't give a try;
1, power on,
2, press "clear","interupt", "0", "interupt"
3, press 14 prss start
4, press clear
Posted on Dec 17, 2008
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 373 Answers
SOURCE: Sharp-MX2700N Maintenance Code VK
Did you try sharp.com/maintenance
Posted on Feb 04, 2009
My sharp mx 350 shows error code L8 :1 how will i reset it?
L8-01 error should reset itself automatically after repair. This code means something wrong with power supply or power distribution. It is job for experienced engineer, all you can do is reconnect connectors of power supply harness.
Aug 15, 2016 | Sharp MX-M350 All-In-One Printer
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
Maintenance code CA
You just need some maintenance, pal.
Have it done and the tech will reset the counter for the maintenance.
If you're in Houston we'd be happy to get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 24, 2014 | Sharp MX-4101N Full-Color Copier/Printer
Horizontal line on output
Clean the small long glass aside the big glass.
Jul 03, 2013 | Sharp Mx-4101n mx-4101n
Sharp copier service mode
To get into the service mode you touch
P * C *
Source:
blog.equipmybiz.com
Apr 11, 2013 | Sharp Mx-4101n MFP Color Copier
Not able to send scans to my mac
Depends on OS version. Older versions worked vwell via FTP newer OS's include windows sharing (samba) and can be set up SMB. If you don't know what FTP or SMB is you may want to call IT.
Jan 10, 2013 | Sharp Mx-4101n mx-4101n
1,212 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
