Question about Dell Dimension 2400 PC Desktop
Audio Devices All of my audio is gone. Everything. I've done everything, it is almost like there was never audio to begin with. there is no sound card detected and there is no way for me to scan for it. My PC is telling me that there are no audio devices installed. But when I go to Add/Remove hardware it says they are all working properly.
  • slim_cruise Oct 31, 2008
    Problem Solver:
  • 6 Answers
Ok... its there, but has been disable. you will have to install the drivers again. That's whats missing. Go 2 Add-Remove programs and un-install it. Then put your disk for your computer (drives only) back in and let the computer install all over again. If you do not have a disk that saids: "Drives", try putting your speakers into the computer...rebooting and see if it detects 'new hardware' and if so, you're in business!! It will automatically install the drivers for you...
You can also go the 'dell' website' search for "sound" and see if they have the drivers for you in their 'download' tab.
let me know what happens, weather good or bad.. i won't mind the criticism!
thns... stay bless!!
'imhere2helpu'
Posted on Oct 27, 2008
  • Dell Master
  • 1,183 Answers
Kinldy download the updated drivers from the following webiste.
http://tinyurl.com/ysy86c
Download
1. Click Download Now, to download the file.
2. When the File Download window appears, click Save (Windows XP users will click Save) this program to disk and click OK. The Save In: window appears.
3. From the Save In: field, click the down arrow then click to select Desktop and click Save. The file will download to your desktop.
4. If the Download Complete window appears, click Close. The file icon appears on your desktop.
Install instructions
1. Double-click the new icon on the desktop. For example labeled R12345.EXE.
2. The Self-Extracting window appears and prompts you to extract or unzip to C:DELLDRIVERSR12345.EXE. (Example path). Write down this path so the executable (Example - Setup.exe) file can be found later.
3. The Self-Extractor window appears.
4. Click OK.
5. After completing the file extraction, if the Self-Extractor window is still open, close it.
6. Click the Start button and then click Run.
7. Type C:DELLDRIVERSR12345 in the Open textbox and then click OK.
8. Follow the on-screen installation instructions.
Thanks
proton
My lap top is telling me I don't have any audio devices
if sound is working on laptop but not on skype, then the settings in skype needs to be set to you audio. go in to skype setting and audio and click on your audio and make it default, same for the mic choose the one you have and make it default. and click on save or ok when done.
Jul 04, 2017 | SMC Realtec Network Card NERENC01
Audio Devices
You need to remove device from device manager and to install back audio driver
Mar 05, 2008 | Compaq Presario 5000 PC Desktop
Sound card
As Acqwerty says, check your audio volume first, put the volume on everything up. Do you have an onboard or seperate sound card? If its onboard you have to make sure its enabled, this is done in the control panel, sound/audio devices. If its a card you put it, check the drivers, and make sure there are no other cards running on the same port as your soundcard, also done in control panel.
Dec 05, 2008 | E-Machines eMachines Desktop PC
Audio Devices
have you tried to install the drivers
Aug 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Audio Devices
on borad one proably no good i would get new x fi sound card use latest driver from web site those onbord ones dont last buddie thats nothing u can do erther come sup or it dont in device manger
Jun 16, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
Audio Devices
Somehow you must have either deleted you sound drivers or disabled them. you can start by looking in you control panel-sytem-hardware-device manager on the list should be something about multimedia audio controllers if there is a yellow arrow next to that then you must have removed the drivers and thus will need to download them from the manufacturers web site.
Mar 12, 2008 | Acer Aspire One PC Notebook
Tascam midi and audio conflict error
First try turning off the onboard audio device using the BIOS interface. Try pressing f4, f2 or delete key rapidly at the flash screen beginning when you first turn on the computer. Look around in the bios (usually in "integrated periperals" area) and disable any onboard audio options that you see.
-In windows XP you can go to Control panel - Sound Devices and change the "map through" feature, select your default device, and run a hardware test simulation with a microphone for each device. Nice setup btw.
Feb 26, 2008 | Tascam US-144 Sound Card
Audio Devices
no sound when i reformat my loptop lavie ll750ad
Feb 14, 2008 | HP Pavilion dv6000z Notebook
Audio Devices
Hi, Firstly if your sound card is not detected then either it needs to be re-seated or it has failed. Is the sound you have an actual card plugged into your motherboard or is it what we call "on board" so actually built in to the motherboard. If it is then you have a problem.
If it is an actual card you can open the box, make sure you will not be voiding any warranty you may have on the machine, then you can carefully unscrew the screw holding the sound card firm and pull the card from it's connectors quite firmly. So long as you don't twist or bend it you will not damage it.
Repeat the actions only in reverse to re-seat the card and screw back in firmly. ( If this does not get Windows XP to detect the card you could try another connector slot if you have one.)
Ok now to the drivers, once the card is detected WinXP will ask for the drivers if it does have them. You can follow the installation wizard and point to where you will have placed the downloaded files.
Ok downloading, can you tell me what the sound card is and then I should be able to tell you where you can download them from?
Let me know
SeaJade
Nov 27, 2007 | Computers & Internet
Audio Devices
Onboard Audigy Drivers
Onboard Sigmatel Drivers
try the audigy drivers first, all install instructions are provided on the download page, if it doesn't work, try the sigmatel drivers.
hope this helps,
trin
Nov 19, 2007 | Dell Inspiron™ E1505 PC Notebook
Dell Dimension 2400 PC Desktop Logo
93 people viewed this question
Alun Cox
