Question about SanDisk Sansa e250 MP3 Player
This is the most ultimate and disasterous problem known to sansa users (me)
This problem is a mix of these following -wheel lights up but not screen -freezes -and........once it gets in this stage it cannot be able to load up music and the computer cannot read the sansa and will not show up on computer now heres the problem many people have run into the problem about the wheel lighting up but not the screen and they have solved it by turning it off (holding on button 30 sec) but.... this time if the sansa won't be fixed after u restart it well... u got yurself a master problem..... oh! and don gimme that lame ass idea about leaving the sansa runing and on and on.....because it won't be fixed after u recharge it..... i guess thats all the problems....... oh well ummm the last resort to do is to return your sansa DO NOT!! I REPEAT DO NOT!!!!!! return your sansa in your first thought thank you for listening METALLICA RULEZ!!!!!!
  • Bushira Jan 09, 2008
    My Sansa is always frezzing up
    all it does is turn on and freeze
    if i put it to charge it turns on but freezez when it on
    ive tried recharging it,didnt work
    ive tried holding the button, didnt work
    its just annoying why it does that
    i got it in december
    its been like 3 and a half weeks (i think) since i bought it
    pls help me i dont want to return it
  • trist1 Jan 09, 2008
    same problem it kept freezing~ now i am getting a "key locked" system shut down message!!
    before all this uploading music from my laptop was a nightmare. i have some songs on the mP3 as double and yet 75% of my other songs i can't listen to b/c it says i need to sync first. syncing with my laptop (i have the windows vista version) has not worked!!
    nothing but a nightmare with this mP3
    Problem Solver:
  • 7 Answers
It has batteries
i thiught u charge it on the computer power
Posted on Jan 09, 2008
Well thus holding down the menu button works for me. except i was holding it for about 2 minutes instead of 15 seconds. so that actually helps
Posted on Apr 12, 2007
Just unscrew the back remove the battery and replace it. turn your player on and presto it works again.
Posted on Nov 28, 2006
SOURCE:
How do you make the scroll wheel turn again?
Your wheel may be stuck because dirt has worked its way into the wheel.
I have 3 ideas--
1) Get a can of computer duster, and try blowing the dirt out from around the wheel, outside and inside edge.
2) Sansa Fuze user 'tenzip' suggests dipping the player, while turned off, in DISTILLED water, if you believe the wheel has something sticky and water-soluble-- THEN let it drain, THEN put the player in a bag of uncooked rice for up to a week. The rice will pull the rest of the water out of the player.
Full discussion may be found here;
http://forums.sandisk.com/t5/Fuze/Need-help-How-can-I-open-my-sansa-fuze-mp3-player/m-p/101570#M38972
3) If 1) and 2) fail, you may want to try opening the player, disassembling and cleaning it, and then putting it back together. Directions with pictures can be found here;
http://anythingbutipod.com/2008/03/sandisk-sansa-fuze-disassembly/
Oct 09, 2011 | SanDisk Sansa Fuze MP3 Player
Top Load Ultimate Care 2 Just below the lid in
This problem is commonly caused by a water inlet valve (also known as a mixing valve) leaking by. If you live in an area that has hard water, or if you use well water, sediment, rust or calcified deposits can accumulate in the inlet valve and cause it not to close properly. Usually when they start leaking, you need to replace them. The following link explains how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
If the model number is correct, the part number for a replacement valve is 285805.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Blank Screen, Frozen, restarts FAT Error message
hold switch up for 15 seconds, this will reset the dam thing
Oct 04, 2009 | SanDisk Sansa Fuze MP3 Player
Song tracks are mixed up on My Sansa Fuse.
What you should do is open the music in windows media player and check the tags and make sure that are all the same. Because SanDisk Organizes by those tags (ie: Artist, album)
Sep 30, 2009 | SanDisk Sansa Fuze MP3 Player
Wheel of my sansa is so sensitive
Hi There,
You need to do the following. I did it to mine yesterday and it's great!
http://joustin.com/?page_id=10
Jan 26, 2009 | SanDisk Sansa e250 MP3 Player
Can't download playlists to Sansa e270
Did you try dragging the songs individually??
Mar 16, 2008 | SanDisk Sansa e270 MP3 Player
hellz yea Metallica kicks ass!!! o and 1 way to solve that problem is by hitting it on the ground.....i dont advise it cause its dumb but i had same prob with my screen and i hit it on the ground and it started working!
p.s. dont hit is real hard or youll jst mess it up worse
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
Sansa c200 mp3 player
Sandisk provides "how-to" videos for everything Sansa related
You should check out the sansa community forums and post your issue, those folks know about EVERYTHING sansa and should be able to help you
Very helpful Sansa user Forum
Offical Sandisk Sansa user Forum
Nov 02, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
125 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
