A MESSAGE SAYING "REAR CHK". ON MY SAMSUNG HT-DB390 HOME SYSTEM
REAR WIRELESS SPEAKERS DO NOT WORK
djnick989
  • 1067 Answers
SOURCE: wireless receiver module is not receiving
if its in standby how do u here anything change audio settinsg to cinma ok dsp mode
Posted on Jan 22, 2008
SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
Posted on Aug 11, 2008
SOURCE: rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Posted on Apr 14, 2009
chipsandnuts
  • 70 Answers
SOURCE: Samsung HT-TWZ312 surround sound probs
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 08, 2009
SOURCE: swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Posted on Dec 19, 2009
I have a blinking code on the receiver (rear chx or rear chk) and have no sound.
The manual is no help but I would think it's trying to tell you there's a short sensed on one of the rear speaker cables. Disconnect them both and see how that works out, then diagnose.
If the message doesn't reset the base unit is sick. take it to someone to look at it.
http://www.retrevo.com/support/Samsung-HT-Z510T-Home-Theater-Systems-manual/id/14714ci454/t/2/
Jan 22, 2011 | Samsung HTZ-510 Theater System
The screen of my DVD is saying protection and none of the buttons are working?
Disconnect the speakers and try again. No good? Fixed? Troubleshoot the shorted speaker leads.
No change? Take it to a shop.
Dec 28, 2010 | Samsung HT-DB390 System
Getting a "fan chk" message on my Samsung HT-TZ512
Did u ever find a solution? The room I use the home theater in gets quite hot. I use an air conditioner but I think prolonged use in the heat has ruined the fan(s). The speakers will power up, and sound can be heard but after a minute or two the CHK FAN will come across the display, and ultimately, shut the system off. Is this what happens to you? T?hanks for any and all responses!,
Ed
Oct 04, 2009 | Samsung HT-TZ512T Theater System with...
DVD's and CD's no longer load in Samsung HT-DB390
REPLACE THE SPINDLE MOTOR,IF STILL FAULTY-REPLACE LASER
Jul 30, 2009 | Samsung HT-DB390 System
Hope this helps!
Jul 05, 2009 | Samsung HT-Q100 System
My main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Mar 13, 2009 | Samsung HT-TZ512T Theater System with...
Rear check message on HT-TXQ120 samsung home theatre
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
Rear Wirelss speaker do not work
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Feb 24, 2008 | Samsung HT-WX70 Theater System
23 people viewed this question
 Grubhead
Grubhead
