Question about Ovens
How do i get my Gibson Euromaster oven door unlocked when its done cleaning?
It was bought around 1993 all it says is its a Gibson Euromaster Self Cleaning oven, i set it for self clean and now the door will not open or unlock
watugot
  • 290 Answers
SOURCE: Kenmore oven locked after celf cleaning
Try putting it back into clean mode and and listen for the lock motor to start turning. If you can hear it, keep trying the door until it opens. Don't hold steady pressure on the latch, just pull a little then let off. After you get it open, hold in on the door switch and cancel the clean mode and it should go back to correct position.
If this doesn't work, you may have a failed door latch, control, temp sensor, or switch. Post back with the complete model number and I will look it up and see which latch assembly you have and see if we can get it unlocked manually.
Posted on Oct 21, 2007
SOURCE: oven door cannot unlock
I know this response is a bit dated, but I just had the same problem. I removed the back panel. There is a little motor that turns the locking mechanism. I removed that and there is a button on a sensor next to the motor. I turned off the power first, since 220 can kill. Then when everything was sorted out, i turned the power back on, hit the switch on the sensor and everything is back to normal. I also made sure that the lock in front was back at 12 o'clock (the L shaped piece at the top of the door, but on the stove),. It worked for us. Good luck.
Posted on Sep 10, 2008
micromaster
  • 3614 Answers
SOURCE: how to use self cleaning oven
  • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
  • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
  • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
  • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
  • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
Posted on Nov 11, 2008
cactus bob
  • 267 Answers
SOURCE: 1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Posted on Jan 15, 2009
  • 10865 Answers
SOURCE: self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
My Gibson Oven oven door will not shut because lock mechanism wont retract?
You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
Jul 27, 2016 | Ovens
What can i do to keep it unlocked and stop the beeping so i can use my oven
Search Results
    Why would my GE range display "unlock door" when the ...
    www.shopyourway.com > Manage My Life > Questions
    If it does, replace the latch assembly. If it continues to display "unlock door", the electronic oven control will need to be replaced. Note: The range will not go into ...
    Troubleshooting a GE Oven That Can Not Get Out of Locked ...
    motherhood.modernmom.com > Around the House > Home Appliances
    Self-cleaning GE ovens have a locking oven door as a safety feature. A self-cleaning cycle drastically ... The oven lock helps keep kids safe while the oven is hot.
    Oven is confused - GE unlockdoor lockeddoor ' Ask MetaFilter
    ask.metafilter.com/255547/Oven-is-confused
    Jan 18, 2014 - The saving grace is that unplugging the oven for 10 seconds and ...There are lots of hits on Google when searching for "GE oven unlock door message".... not lock, which meant that it would not do the self-cleaning cycle.
    How to Unlock a GE Oven: 9 Steps (with Pictures) - wikiHow
    www.wikihow.com > ... > Microwave Ovens
    wikiHowThe self-cleaning oven function is a time-saver and it increases the safety of ovencleaning. During the ... Luckily, there are several ways to unlock a GE oven. Ad ...
    Range - Oven Door Won't Unlock - GE Appliances
Jan 25, 2016 | Ovens
Oven will not unlock after self cleaning
User manual says that the oven must cool off. I am sure this is not the case. Try starting the oven self clean function, and then clear/off to stop the function. Since the oven is cool, perhaps the oven will unlock.
Finally, you could try turning off the circuit breaker and then back on to see if it unlocks - unfortunately you will have to reprogram everything. All else fails, call a technician.
http://www.manualslib.com/download/58340/Ge-Jt912-Jt952.html
Mar 04, 2015 | GE Profile JT952 Electric Double Oven
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 | Ovens
Used the "self cleaning" to clean the oven and when it was done and cooled down the door at first said it was unlocked and then the "door locked" light started flashing and it sounded like the door was...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock light blinking ,oven wont work on a older gibson self cleaning oven.
It sounds to me that the door lock switch itself is stuck in the "on" position. If you don't use the self-cleaning feature, I would suggest simply disconnecting the switch. If you DO use the self-cleaning feature, you may want to consider replacing the switch or inspect it to make sure there isn't debris, grease, etc., stuck in it, making it stuck on all the time.
I hope this helps! :) Please let me know if you need any further assistance in this matter and I'll be more than happy to help!
Feb 21, 2010 | Ovens
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 | Ovens
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
heatman101
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Oct 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
