Question about Garmin StreetPilot C330 GPS Receiver
320 streetpilot Won't turn on only used 3 times how do i change the battery
I only used this item about 3 times and it is sitting for about a month now. I went to use it yesterday and it will not charge on the usb port of my computer or on the car lighter do you think it is the battery. If so how do i change it.
  • 4 Answers
Plug your Garmin in the next time you are planning to drive for a couple of hours and let it charge, if not that then it is the connection wire is loose at the base of the unit...go to radio shack if your wire is bad....they have them there.
Posted on Oct 29, 2008
Engine won't start after setting 3 months with good battery turns over but won't fire what the problem
3 months is along time for gasoline to sit. Use starting fluid to see if you have spark. Caution with starting fluid its extremely flammable.
Feb 18, 2017 | Hyundai Cars & Trucks
Remote went dead, tried charging won't charge.
Did you try removing the battery? with the battery removed push buttons then let it sit for a few minutes with no battery in it. Then reinstall the battery and see if it powers up, if not then let it sit over night with the battery removed then reinstall. If all that fails then I would say its a goner
Oct 12, 2017 | 3303 2way Security System
Garmin streetpilot 2610 does not turns on!!
There is no battery on Garmin Streetpilot 2610 so you have to plug it in !!!!
Feb 10, 2013 | Garmin StreetPilot 2610 GPS Receiver
McCulloch 320 chainsaw, won't start, removed spark plug, it was saturated in gas mix, how do I fix it? Guess I should ask if it's worth fixing first, lol...Thanks
If the saw had been sitting a while, especially without fuel stabilizer in the pre-mix,. change out the fuel and try a few more times.. it si a goof idea to allways use fuel stabilizer fro all the small engines..
Best regards
Ck
Sep 09, 2011 | McCulloch Garden
Been sitting for six months won" start
try your battery first most of the time thats the problem when you turn on your engine you should have lights if you dont then your battery is dead and that is the problem would reccomend you either charge the battery if that dosent work replace it but check first if lights are working a 6 month lie up would deaden your battery best of luck also any battery charger would do for the charge and also on a short term you can jump it from a car battery with the leads just to make sure its the battery also but do not try and charge from the car just check to make sure its the battery by doing this
Mar 16, 2011 | 2003 Honda CBR 600 RR
I require a new battrie for a c 320 .garnum p/n361-00022-00 .and price
You could buy the Battery from :-
http://cgi.ebay.com/Battery-for-GARMIN-Streetpilot-C320-C330-C-330-320-ACCU_W0QQitemZ370262074141QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item563556e31d
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 08, 2010 | Garmin GPS
Battery on my garmin c510 sat nan wount hold a charge how easy is it to change
Had the same problem. Fixed with a new battery. Takes the same as a Streetpilot c530 and can be purchased anywhere on line. A 10 minute job with a soldering iron.
1. Open face plate. Unscrew 4 screws. Remove battery connector and clip.
2. Unsolder the wires to the two speakers - 4 wires.
3. Remove the sticky wrap from the old battery and place around the new one (to stop it rattling).
4. Solder back the new speaker wires.
5. Plug in battery, reassemble unit and charge Garmin off PC wih usb cable.
Done!
Sep 15, 2009 | Garmin StreetPilot C330 GPS Receiver
How to replace battery of Garmin StreetPilot C530 GPS ?
This is not a job for amateurs. You will need a few special tools, and a new battery (3.7 volt / 2200 mAh).
1- Use an old credit card to gently pry off the aqua-blue bezel from the face. That's the piece of trim that fits around the screen.
2- You will see four small #0 Phillips screws. Use a #0 Phillips driver to remove these four screws. You must have a steady, firm grip, and apply a good amount of pressure, or you can strip the heads. Try turning each screw just a tiny bit at a time, until they turn easy.
3- Sit the unit on a table, with the display facing up, and the serial # facing you.
4- Grip the front part, with the display, and pull it out of the back dish, about 4 cm. You may have to jiggle it a bit, to get the steel bracket holding the satellite detector to come loose. Do not yank it further than about 4 cm or you can rip off the flat cable.
5- Fold the display down, toward you, and rest it flat on the table.
6- You will see a steel bracket holding the battery in the dish part. Remove the two #0 screws holding the battery bracket. You may have to peel it off the battery, if there is adhesive around the battery.
7- The hard part: You have to decide to solder the new leads to the speakers (if your new battery came with the special connector), or else clip the 3 wires from the old battery and splice the old leads/wires to the new battery.
Aug 02, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin streetpilot c330 problems
my c330 shuts off after 3 seconds and then wont start back up . on battery or adapter
Apr 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot i3 wont power on
WARNING: You will lose all user data when you do a master reset.
To erase all user data on the device, please follow these steps:
  1. With the unit turned off press and hold the thumb wheel down, then press the back arrow and hold down, then press the power button.
  2. When all 3 are held down a message will appear that reads "DO YOU REALLY WANT TO ERASE ALL USER DATA". Select "Yes".
  3. Let go of the buttons and go through the reset sequence. The unit will need to sit outside to acquire satellites.
Dec 18, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
