Question about Dacor MCS130 Millennia Electric Single Oven
Does not work after self cleaning.
A couple of days after self cleaning ( only 2 hours) the oven does not heat, even it shows that the oven is on "heat".
We had this problem before, and a service man re-set an overheat switch. Unfortunately I was not there and didn't see where that switch was.I looked everywhere; inside, inside the switch panel,there seems to be a sort of braker near the door lock motor but it didn't move. My model # exactly is:MSC1305
  • klaus58 Oct 27, 2008
    Problemwas not resolved by disconnecting power for 25 min. It did not make any sense either.
    ( I am a very practical person)
    Genius:
  • 1,550 Answers
Behind the door latch assembly there is a thermostat with a reset button on top.
When its tripped everything will appear to work, but just no heat in the oven.
Use a wooden spoon handle to reach behind the oven door latch and push down on the button.
Your oven should work after this point.
Posted on Oct 27, 2008
    Scholar:
  • 155 Answers
Replace the thermal fuse and thermostat sensor from the local parts shop ($30) and installed it yourself its very easy.The sensor is in the back, just above the convection fan.
do it care fully.
keep the unit OFF when you do this.
thanks.
  • 728 Answers
Maybe it detects that a trace of the auto clean stuff used to clean the oven is left and it may be flammable and it goes into auto-shutdown until the traces are removed. I know you might not like it, but try wiping down the inside of the stove to be sure there are no traces of any cleaning stuff left. Then try leaving it unplugged for a while and plugging it back up so it can have a fresh start and then try it. It should work.
  • 4,472 Answers
Have you gotten any F codes on the display?
Thanks,
Lee
  • Dacor Master
  • 19,396 Answers
Try unplugging power cord for ten or twenty minutes, this should reset the sensor the same.
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
I purchased my maytag double oven February 2011 and it has worked great. This morning I used the self clean cycle on top oven for only 2 hours. But after it cooled and unlocked I realized I needed to clean...
you might have to clean it YOURSELF....
umm, power down at circuit breaker for a minute, power up, reset clock and try again.
otherwise wait a few days.
Oct 14, 2013 | Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Oven door locked - display shows F5:E7
Hello there and thank you for choosing fixya
These codes normally show up during the cleaning cycle this is due to the extreem heat used during the self clean operation
Now to fix this is not too hard providing the sensor for the temperature has not been damaged due to the heat
Unplug the oven and leave it sit for 1 hour and do not touch there is a internal reset feature on these ovens that take 1 hour to reset once the hour is up plug in the oven and you may hear a audiable click sound or a buzz sound if so great then all you have to do is to press the cancel or off button then after 5 min attempt to unlock the door
if it does unlock and one of these error codes are still showing this means the the controle panel has suffered some damage and needs to be replace
I have seen brand new ovens have the controle panel fail after the first self clean operation because the parts inside of it fail due to the extreem heat ok?
Hope this helps
Best regards Michael
Apr 20, 2011 | Ovens
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
hello,
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    RENTING CONDO WITH SELF-CLEAN WHIRLPOOL OVEN RF376PXDQ
    If this a relatively new oven it show have a self cleaning identification on the control area or panel. Just close & select self cleaning option should take about 1 1/2 - 3 Hours
    Mar 25, 2009 | Ovens
    How much time to leave on self cleaning...clock does no work
    Depending on the condition of the oven, it could take up to 4 hours.
    I ran the auto self clean on my oven last week for the first time and it set automatically for 3 1/2 hours. (It stunk, but it worked.)
    A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
    Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
    Dec 15, 2008 | GE Profile JTP18 Electric Single Oven
    Dacor MCS130 Millennia Electric Single Oven Logo
    395 people viewed this question
    Top Dacor Ovens Experts
    Dan Webster
    Dan Webster
    Vitaliy Gins
    Vitaliy Gins
    ashburton
    Are you a Dacor Oven Expert? Answer questions, earn points and help others
