Question about Proform 980 CS Treadmill
How to replace the incline sensor on a proform 980 cs treadmill
SOURCE: My Proform treadmill will not incline. It is stuck
My proform treadmill is stuck on the highest incline (10) and it doesn't budge from there..Help my workouts are killing me!
Posted on Jun 24, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
outfield502
  • 79 Answers
SOURCE: the proform 730 CS treadmill is stuck in the
The only way is loosening the screw or nut and making it back manually, but it is the right way to fix it, you should review the KEYPAD, specifically the down key. tries to do the following: turn it off and rub the area where the key now is turn it on again if it does not work with you to replace that part
Posted on Feb 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jun 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Posted on Jul 16, 2010
Incline trouble.
You most likely have a wiring harness problem. Get parts at usedtreadmillrepairparts.com
Dec 25, 2013 | Proform 7.0 Crosstrainer Treadmill
My proform 750 CS will power up and incline but the motor won't start moving. While performing troubleshooting on the MC-60 SCR Motor Controller the D11 LED is the only LED lit up on that circuit
please LUBE the deck belt+rollers bearing. see the video attached.
If the problem persist TIME to replace the old deck belt board.
This happen because the lack of maintenance schedule in LUBE.
God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor2_4_2013_6_01_12_pm.gif
Feb 04, 2013 | Exercise & Fitness
Pro-form 980, regardless what button I hit the speed goes to 12
1) test the speed sensor, for open or faulty, see the adjustment. Clean if and tight the connector very well
2) tight the ribbon cable for keypads , and clean it
3) replace batteries,and clean the contacts baterries very well
4) adjust the Reed swtich, test for open or faulty, clean it and tigh the connector very well see the diagram
5) Run the software calibration for troubleshooting, diagnose, and fix it.
Jan 22, 2013 | Proform 980 CS Treadmill
I have the pro-form 980 cs and the screen displays a bright blue color but no words on the display. It was working fine, but a storm over the weekend knocked out our electrical power. It has not worked...
Dear Friend:
Thank you by your request.
I will try to help you inmediately:
nstructions Things You'll Need
  • Phillips screwdriver
  • Allen wrenches (included with the Proform 980 and Proform 980CS)
  1. Power
    • 1 Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
    • 2 Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3 Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 98CS and a horizontal switch on the 980 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
    Reed Switch
    • 1 Unplug the treadmill and remove the safety key.
    • 2 Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 980 Interactive trainer and four screws on the 980CS.
    • 3 Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
    • 4 Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
    • 5 Reverse the directions to put the hood back on and the treadmill upright in the original position.
    Optic Sensor
    • 1 Unplug the treadmill, take out the key and remove the hood cover.
    • 2 Locate the optic disc and optic sensors. The optic disc is the only circular disc set between two optic sensors.
    • 3 Spin the disc with your hand. It must spin without hitting either of the sensors. Loosen the adjustment bolts that hold the switches in place with the included Allen wrench and adjust them to ensure they do not interfere with the discs' ability to spin. Tighten the bolts and replace the hood
    Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Sep 28, 2011 | Proform 980 CS Treadmill
Beeps when buttons pushed, but won't start
Dear Sir:
Try it with some little Inyection of 50% of Oxigened Water +50% ethilic Alcohol(100%) for to clean the contacts or pad for the buttons.
Wait for 15 minutes.
An try it again.
Now if doesnot work go to the 2 Step.
2) You must open the cover, and look for the rely for to clean it contacts, in the same ways.The rely is the element for to swith off -and on the motor for Theadmill.
Respond it if you get solution.
sincerely.
E.Cuadra
Sep 05, 2011 | ProForm 980 CS Treadmill
My Proform 380 treadmill will not run the incline goes up and down but the motor/ belt does not move
ADJUST 1) Reed swithc and optic disk.11_15_2011_9_21_16_am.gifIf after you did these adjustments Not work, replace the sensors.11_15_2011_9_21_36_am.gif
May 31, 2011 | Proform Crosswalk 500 Treadmill
My Pro-form 980 CS will not start. I plug the key
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Jun 12, 2010 | Proform 980 CS Treadmill
The proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Apr 30, 2010 | Proform 980 CS Treadmill
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
The proform 730 CS treadmill is stuck in the inclined position. It doesn't go down when pressing the down arrow. Is there a manual way to lower it.
Feb 05, 2010 | Proform 730 Folding Treadmill Model...
Proform 980 CS Treadmill Logo
26 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
