Question about Sony KV-36FS17 36" TV
Hooking a computer up using this TV as the monitor
The computer is a Dell desktop Dimension 4700 - about 4 years old. No S Cable hook up but it does have a DVI connector in the back for a monitor. Is there a way to do this? I've had several answers but would like to hear a more expert opinion. We were told we can buy a computer audio output to a stereo cable. That should take care of the audio but what about the video? Is there a solution? Thanks! mamalu5@comcast.net
  • 39 Answers
Look fo r a vga to DVi cable connector
Posted on Oct 27, 2008
Whenever the monitor is turned on, it displays for about 3 seconds and then goes black. what to do? It is only about 3 yrs old
One of three things is the most likely culprit.
1. Onboard video card is either disabled or bad.
2. Cable is bad
3. Monitor is bad.
You can check the last 2 relativly easily by hooking the monitor and cable up to another computer to see if they function. if they don't then first try swapping out the cable (i say this first because its cheaper) then swap out the monitor.
To see if the video card is bad try hooking up a different monitor to the system. If the new monitor is not displaying anything then you most likely will need to put a new video card in the machine.
Apr 18, 2011 | Dell Dimension 2400 PC Desktop
Hi, I have a dell dimension e521 I hook up a old monitor to it and, it work but whei i hook up a new flat screen monitor it said (can not display video
Are you using the same VGA cable. Try to use the same VGA cable which is there is in Old Monitor
Though it can be issue with the resolution setting also of the Video
For that when you plug in your desktop to old monitor bring the Resolution to the minimum and then Connect it to your New Monitor
Jan 06, 2011 | Dell Dimension E521 PC Desktop
My dell 4700 won't come out of sleep mode, i've rebooted and changed the internal battery but still no luck
Get some canned air - 2 cans
unplug the monitor and computer.
Use canned air to blow out all the vent holes of the monitor.
Leave it unplugged for about 1 day.
Open the computer case. Use the canned air to blow out the computer. pay special attention to fans and the power supply - actuall blow the air through the power supply vents on both sides.
If you have an add on video card (not on the motherboard), remove the screw at the back of the case, and remove the video card. Reinsert the card and make sure it is tight. replace the screw.
After the day is up plug the monitor back in and use the buttons on the front to enter the monitor menu. Choose to reset or factory settings.
Hook it back up to the computer and boot the computer.
If the problem still occurs try the monitor on another computer or laptop.
If the problem goes away by hooking it up elsewhere - replace the video card.If you are not sure what type to purchase just post back model and serial of the computer.
If the problem is still there after hooking the monitor up elsewhere,
Try changing the video cable or seek rpelacement through warranty or purchase a new one. Check newegg.com for best prices.
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
Nov 20, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Video Card upgrade for Dim 4700 to 1920 x 1200
go to dell's web site.
http://support.dell.com/support/topics/global.aspx/support/upgrades/en/segmenter?c=us&l=en&s=gen&~ck=mn
Fill in the requested information and they will give you the details of your computer, and recommended upgrades.
Does your current card meet your needs? The 24 inch should not need any thing special other than loading its drivers, and setting up the video. You will of course be using the "D"
15 connector on this monitor and a mating video cable. These have to be purchased on their own sometimes, so make sure one comes with your monitor.
Aug 07, 2009 | Dell Dimension 4700 PC Desktop
No audio/cable box to computer monitor using hdmi/dvi
Hi lauriesbc
if you take the audio feed from your cable box via the line out sockets then plug into line in on your sound card you shud be able to get audio.....
hope this helps
Feb 16, 2009 | Dell Dimension 3100 PC Desktop
Hooking up speakers
The speaker output jack is green as indicated on the setup diagram which can be found here: http://support.dell.com/support/edocs/systems/dim4700/en/index.htm as for the speaker cable itself it may or may not be green. The other jacks are for various input/output devices such as mic, aux, etc.
Nov 28, 2008 | Dell Dimension 4700 PC Desktop
Video out on dimension 2400
all of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Oct 09, 2008 | Dell Dimension 2400 PC Desktop
Dell dimension monitor not working flashing on when unplugged and plugged back in
hi Fshumway, time to change your monitor, it is a problem on this kind of monitor, it is 20" ? or somekind of energy problems, or in the cable conector in , to your computer, is bad. If you have other monitor, use it, and see if work fine.
hope this help!
Carl
Nov 05, 2007 | Dell Dimension 4700 PC Desktop
Sony KV-36FS17 36" TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
