Question about Drills
Where can i find drills and chisel to a 726 skil roto hammer im in mexico
Chuck68
  • 42 Answers
SOURCE: Chuck broke on my hammer drill
To take a chuck off of your drill open it up all the way.
Inside there's a screw that you have to take out. It has to be turned clockwise to get it out.
You may need to struggle with it a bit because it's usually really on there tight.
Some folks even use a second drill to loosen it up and that's a really good idea if you have access to one.
Once you get the stubborn little screw out, put an Allen wrench in the spot where the bit would fit in.
If you can't turn it--and you probably won't be able to--then try using a rubber mallet to (gently) hit the arm of the Allen wrench to get it to turn.
Then you should be able to just take it out.
Put the new chuck into the drill.
Add a few twists of the Allen wrench in the opposite direction.
Tighten it up good.
Put the screw back in place and also tighten that up good.
The drill has a lot of vibration and if these aren't tight, it'll cause problems down the road.
Your drill, expertly fitted with your brand new chuck, should now be good to go.
Please rate this solution
Posted on Jan 13, 2009
comax
  • 154 Answers
SOURCE: Chuck broke on Skil hammer drill
As long as the new chuck threads onto the old spindle then any chuck will work fine.
Posted on Apr 13, 2009
  • 211 Answers
SOURCE: pbh 2200 re hammer action drill
hi
try to figure out how the switch operation mode works and put back together right.
bye savumihai71
Posted on Sep 16, 2009
SRF518
  • 232 Answers
SOURCE: Skil 3/8 Hammer drill #6425 chuck ring broken in half
get a new chuck - thread is a 3/8-24 left hand thread
Posted on Oct 23, 2009
  • 8404 Answers
SOURCE: i have a old skil electric hammer drill with a 3/4
Go to a tool rental place with your drill and see if they can match you up with a proper tool for it.
Thanks for your interest in FixYa.com
Posted on Feb 15, 2010
Can this drill be used as a hammer only for chipping?
if it is an elcheapo drill then it cannot be used for hammering only
it can only be used as a drill or a hammer drill
what you need is an expensive hammer drill ( Ramset or HILTI for masonry work that can accommodate a chisel tool and be used for chipping
however if you want to just chip there are cheap air driven chisels , that will do the job
find a good tool shop and there will be a range of tools that will do what you want
Sep 13, 2015 | Hammer Drills
My Hilti TE 17 roto hammer rotates but wont hammer
This one should have a knob or lever on the side of it to switch between "drill" and "hammer plus drill" It can be used as either a regular drill or a hammer drill.
Nov 13, 2014 | Drills
How to chisel
The Bosch 1199VSR Hammer Drill is capable of drilling or hammer drilling at two different speeds but can not hammer or chisel only. To do that you need a demolition hammer or roto/demo hammer tool.
Jan 28, 2012 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
Stuck chisel
if you have access to a vise I would lock the chisel in it and pull on the release collar and then take a dead blow hammer and "tap" on the drill to try and pull it away from the chisel.
Jun 28, 2010 | Bosch 11265EVS 158 Spline Combination...
Oct 22, 2009 | Skil Drills
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Sep 12, 2009 | Skil Drills
Dec 19, 2008 | Drills
Drills Logo
66 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
