Question about Akai PT4298HD Rear Projection Television
Akai 4298 projection tv
I am having a problem with a blue line on the top of the tv that arc's downward....I tried the manual convergence function, and I see the lines move, however this blue line is arc'd way to far downward. Any ideas? The blue and green are just fine....Thank you very much for your service!!!
  • 2 more comments
  • circuitblown Jan 27, 2008
    Have the same issue resolution was too vague in answer by Tekie.
    Help appreicated.
  • rkeinc Feb 17, 2008
    I have an AKAI HD television I
    purchased in October 2003 that has
    been a marvelous product.
    Recently it started to display a
    "blue" shadow. When I tried to
    perform "perfect focus" red and
    green would succeed but blue was
    dimmed out and did not focus. I
    suspect there is something wrong
    with the blue processor/convergence.
    What options do I have?
    Here is the information to the
    television:
    Manufacturer: AKAI
    Type No: PT4298HD
    October 2003
    Model No: PT4298HD
    SVC Model: PT4298HDX/SMS
  • redsoxfan11 Feb 23, 2008
    television:
    Manufacturer: AKAI
    Type No: PT4298HD
    Model No: PT4298HD
  • Lugina Jun 07, 2008
    I have the Akai PT4298HD as well and I am able to adjust the red convergence but don't understand why I can't adjust the blue. There is no movement when I try to do the same adjustments as I did the red. I have just recently signed up with cable and about a week after, the convergence seemed to become out of adjustment. Can you help?
    Genius:
  • 1,694 Answers
Use first quality IC's (no generics).Be sure to check all fuse
devices-usually one or more pico fuses opens.
Posted on Oct 18, 2007
    Scholar:
  • 27 Answers
Most likely, this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Hope this helps ...
Posted on Oct 06, 2007
I have an Akai 42"
Its usually the convergence board just replacing the old board with a good one should solve the issue. You can get the convergence board for the PT4298 at the following link just scroll down the page. http://www.tvrepairworld.com/samsung__akai_circuit_boards
Jun 24, 2011 | Akai PT4298HD Rear Projection Television
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
The picture arced and looks 3D. Plus the screen
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 10, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Blue arc and ghosting across middle part of screen.
Replace Both of your convergence ICs they are big Black ICs will have STK on them! Use STK392-150s or the 180s Better ICs Call Mats Electronics 1-800-628-1118
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Akai
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 31, 2009 | Akai PT4298HD Rear Projection Television
Color separation Akai model pt4298HD
  • Screen looks 3D
Jan 06, 2009 | Akai PTH5498 54" Rear Projection...
PT4298HD Double image
BINGO thats exactly what i get paid to do same price 285.00
Nov 30, 2008 | Akai PT4298HD Rear Projection Television
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
AKAI PT55
The green convergence can only be adjusted through the service menu
Feb 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
371 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
