Question about Watches
Michael kors watch band adjustment - Watches
I need to buy an extra links for MK watch... Please where can I get ir
Posted on Aug 26, 2013
5 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Wirst band problem
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 28, 2009
disap1
  • 98 Answers
SOURCE: i have a michael kors white ceramic watch and the
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Posted on Jan 16, 2010
  • 2501 Answers
SOURCE: I accidently dropped my Michael Kors white ceramic
If you copy the following into your search engine, you will be able to contact Michael Kors to discuss your problem.
"/www.michaelkors.com/store/service/nmAssistance.jhtml"
Posted on Feb 18, 2010
  • 2501 Answers
SOURCE: I bought a Michael Kors watch and need HELP!
Have you thought of changing the band to a leather one?
This would allow you to make holes in the best place to give the correct length for you.
Alternatively you might be able to get an expanding metal type which would solve the problem. This type can also be adjusted for length.
Posted on Mar 19, 2010
Testimonial: "This is a good idea and one I hadn't thought of. However the main reason I bought the watch was for the tortoise shell watch band. I'll keep thinkin"
How do I remove links from Michael Kors watches?
I keep getting spam about michael kors watches too.
Aug 02, 2014 | Michael Kors MK8072 Wrist Watch for Men
Bwhat do i clean white resin watch band
Hello, here is an article with tips to clean watch bands, and according to several of the comments, the process was successful on several Gucci and Michael Kors watches as well.
May 10, 2014 | Gucci Watches
How can I remove the band from Michael Kors watch?
Tripti, do you have any watch repair tools? If not take to a repairer with your replacement band. Don;t risk damaging a good watch.
Mar 03, 2014 | Watches
Replacement band
Contact MK for the band the replacement is not available aftermarket. It is a common problem with the silicone bands.
Oct 01, 2013 | Michael Kors MK5145 Watch
How to resize Michael kors mk5216
Arrows on the inside of the band shows the direction that the pins should be pushed out.
Feb 16, 2013 | Michael Kors Womens Acrylic Brown Dial...
Broken band on MK5235, where or how to fix it?
Only one place if you need anything other than a pin or screw. That would be the manufacturer. I a pin or screw is what is required, go to a watchmaker. They will have the required part usually. My experience is not good dealing with fashion watch manufacturers. Look in the booklet that came for your watch for the M Kors service center and call or write for directions. Good luck, Michael
Nov 03, 2011 | Michael Kors MK5235 Watch
Mar 19, 2010 | Watches
I have a michael kors white ceramic watch and the band is too long? how do i remove links?
Jan 15, 2010 | Watches
Watches Logo
4,388 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
