Question about Cycling
My dinli 90cc atv has no spark
It wont start the plug has no spark it has compression just no spark an i dont know if its just the plug or if its done for
2 Suggested Answers
  • 6 Answers
SOURCE: I have fsn 90cc atv that I cant get no spark to
try putting in a new spark plug in
Posted on May 25, 2009
I have a baja 90cc quad it dose not have kickstart i put in the key and it wont start i got a new sparkplug and a new battery still wont start
Do you have fire at the spark plug. If so check compression, then if not check fuel system(( carb)
Jul 29, 2017 | ATVs
90cc four wheeler won't start
Check for spark.make sure it's ON . pull plug and rest plug on bare metal and turn it over . If u see spark in plug gap it's not stator or coil or Cdi .,., it's a fuel issue chase it from bottom up carb to tank
Nov 12, 2016 | ATVs
Does the spark start at the mag on a 2003 90cc Honda ATV?
Its time for a professional, take your Honda to the HONDA dealer for assistance
Sep 01, 2014 | Cycling
90cc quad chinese wont fire. New battery cleaned the carb the 2 jets and the little one that is on the float. Compression is fine and spark is fine. It cranks and cranks but will not start. So its getting...
just for fun, while you're cranking it put your hand over the intake of the carb completely covering it and see if your hand gets wet with gas. this might even start it too.
Jul 17, 2017 | ATVs
My 90cc outlaw wont start
ignition or solinoid
Nov 23, 2011 | Polaris ATV
My Polaris Sportsman 90 ATV has 70lbs of compression on the engine is that enough ? It does not start .
70lbs for a 90cc should be good, but 80-85 is better. Compression drops from piston rings wearing out, most of the time. Piston rings wear out from old oil...every time. Rule of Thumb: 5 tanks of gas, change your oil !!! It's not a car !!! A car has 5 quarts of oil which takes about 3 months to break down (2,000 miles or so), 90 cc engine has a half a quart, which takes about 3 weeks to break down (based on everyday use) SO...5 tanks of gas, change your oil..
as for the not starting thing, check for spark (should be a blue spark ONLY, any other, replace plug, orange won't ignite gas) if you haven't been riding for a while, open the drain screw on the bottom the carburetor and drain the water out. Ethanol turns to water when the gas sits too long...
Apr 09, 2010 | Polaris ATV
My 2002 polaris trailblazer wont start it has fire
If you have oil and gas and it will fire then try a new plug. A bad plug when removed will appear to be fine but under compression can fail.
Also try a splash of good gas in the throat of the carb or intake (if fuel injected) with a new spark plug. My bet is it fires just fine.
If this is a fuel injector type engine you could have a bad injector control unit or a clogged injector.
If it fires with gas in the intake manifold then suspect carb or injector system. (which ever applies)
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Polaris ATV
Cycling Logo
158 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
