Can't print from mac to savin c2820
Printing blanc pages
SOURCE: dsc328 will not print using a Mac
If your copier / printer does not have postscript 3 option installed, it will not print from MAC. Print a configuration page: "User tools", "Printer features" "list print" (or similar), "configuration page". Check under the heading of "printer languages"......you'll see stuff like "PCL 5c", "PCL 6", "RPCS", etc. If no "postscript 3", it is not compatible with your MAC, and you don't want to know how much that option is for your machine! Ridiculous!
Posted on Feb 25, 2009
  • 143 Answers
SOURCE: Savin 2513F, prints PDF files intermittently
I'd try a different driver, if your using RPCS, change to PCL5. You may have to upgrade the firmware in the copier too.
Posted on Aug 27, 2009
  • 51 Answers
SOURCE: am at work on Savin
Check whether the print key on ur printer is stuck anywhere
Posted on Jul 04, 2010
M2Tech1
  • 313 Answers
SOURCE: I'd like to print from a Mac (OS 10.4) but instead
Hi first have you installed the correct Mac drivers the default drivers would be winds and if youj installed from disk this may explain...Go to Ricoh.co.uk and then select the downloads tab and network drivers on the right hand tab. then you will have to select correct machine and OS make sure it is Mac. this will guide you to an external site to down load save to a folder and then install from there. Hope this helps A.
Posted on Sep 16, 2010
dwylie76
  • 80 Answers
SOURCE: I just installed driver for
For a Mac to print to the Sharp MX-2300N the Postscript Kit (MX-PKX1) has to be installed on the copier. If that is not installed you will not get any mac to print to it.
Posted on Nov 10, 2011
Black will not print on a savin clp22
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Oct 16, 2013 | Savin GENUINE RICOH FUSER UNIT (402451)...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Can not connect my SAVIN 9925dp copier to a computer.
depends. these machines did not come standard with print option. do you have that option? if so does it have a parrell or nic? the nic is the new stanard connection, ethernet j45 connector. are you printing mac? if so you have to have the post script ooption in addtion to the nic and print card.
Sep 25, 2009 | Savin Office Equipment & Supplies
When printing an email the printer segments one page into two or more pages leaving a lot of blank space on each page
almost souunds like your computer thinks your printer is a different model check in the drivers section.
control panel/ System / Device manager / imaging devices or printers open it and then update driver.
IF that is up to date then what is happening is that on some web sites they have frames and it will print the header at the top of the page on one page and then it will print your information and then a few more blanc pages. Try to print just the page your viewing in your properties section of your print properties.
Hope this helps
Cheers
Al
Sep 11, 2009 | Office Equipment & Supplies
Aug 26, 2009 | Office Equipment & Supplies
Savin 8045e copier
That depends on what you are printing.
Any time you read stats about page count, it is usually based on 30% coverage of the page.
Depending on what you are printing, it can be more or less.
Estimated yield is 30,000 pages for a standard cartridge.
Using an aftermarket (refill) cartridge can vary greatly.
And as mentioned, it really depends on what you are printing.
Aug 05, 2008 | Office Equipment & Supplies
35 people viewed this question
k24674
