Question about Hoover Washing Machines
I have a Hoover 800 RL washing machine. Cant find where the wash filter or lint catcher is?
Does this model have a wash filter or lint catcher? Cant find it anywhere
  • 115 Answers
SOURCE: hoover 800 RL toploading washing machine
if you use liquid fabric softner that is what it is sort of looks like grease what happens is that softner gunks up and gets up under the agitator then when your lighter clothes are washing it shows up you need to take some stuff called washer magic and just follow the directions on the bottle
Posted on Jan 01, 2009
  • 351 Answers
SOURCE: hoover 800 heavy duty washing machine
the clicking sound could be the brake arm worn its white and in the middle near the gear box,the reset is for water only.the outlet pump is at the back where the drain hose comes out.the filter is in the middle of the agitator just pull it out.check the belt isnt loose.
Posted on Mar 02, 2008
MNTECH
  • 1543 Answers
SOURCE: where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Posted on Feb 01, 2009
SOURCE: Cannot find lint filter in washing machine. Is there one?
I called Home Depot where I purchased the washing machine and they told me newer washers do not have filters any longer.
Thanks for your response.
Posted on Apr 16, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Top load GE High Efficiency washer has been leaving excessive lint on dark clothing. How can I fix this problem?
Clean out filter also spin clothes in dryer the lint catcher in the dryer will catch the lint.
Nov 15, 2014 | Washing Machines
Is there a lint filter on a hoover electra 540 washing machine
Did you get a manual with machine? answer is in there. if not google your units name and model number with the word manual and it should come up
Mar 12, 2011 | Hoover Washing Machines
I can't find the filter location for Hoover 202M 5.5kg washing machine. Can you pls help.
The filter is in the agitator. Remove the agitator cap, and you will find it down there. The filter is pretty much useless. Even though you might get some lint in the filter, if it wasn't there the lint would go down the drain. This machine has a neutral drain feature where the lint gets pumped out with the rinse water before the bowl turns, so preventing the lint from being stirred up nd put through the clothes. Cheerts Tony.
Sep 07, 2010 | Washing Machines
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Dog hair remains on clothes/blankets after washing
if you want suggested answers you have to provide make, model and type of washer ( top/or front load )
if it is a westinghouse , simpson, hoover or like make top loader , there is a lint catcher bag at the end of the center spindle cover that you simply pull up and unclip and turn inside out to clean
Soe put the detergent in that cover for the washing
Mar 18, 2017 | Kenmore Washing Machines
Diamond ring went through wash cycle
If there is no filter to be seen at the fron t of washer, then remove the rear cover, locate the large blkck hose fastened to bottom of drum, remove and check inside the hose, there is a good chance the ring could be trapped in the hose.
Good luck.
Feb 11, 2010 | Washing Machines
Where can I clean lint out of GE front-loader washing machine
Feb 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Kenmore Model #110 washer
They have not been putting lint catchers in washers for 15+ years now. The new method the 110 washers use is by having rough sharp edges on the outside of the basket (where you place your clothes) As the water runs through the holes in the basket lint is caught by these sharp edges. Once the spin cycle begins, the lint is flung to the outer tub and washed down the drain in the house.
Jun 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
