Question about Belkin Hi-Speed USB 2.0 DVD Creator (F5U228) Video Capture
Belkin Hi-Speed USB 2.0 DVD Creator + Sony TRV65E Hi-8 Camcorder
Hi, Please could help me fix the below problem I am having. I have a Belkin Hi-Speed USB 2.0 DVD Creator (F5U228) with a Sony TRV65E Hi-8 Camcorder. I have it setup to capture some old footage of my daughter that I would like to put onto DVD. The problem I have is that it will only seem to capture in black & white. I have made sure the footage is okay by testing it on my tv, it appears in full glorious colour. I have also made sure all settings are set to pal and have also tried using s-video cable instead of composite. When its capturing there is a frequent flicker of colour trying to come through but its just a few lines. I have located and installed the latest driver for the device and also the latest video driver for my laptop (PB Easynote H5, 64MB nVidia go5100) without any joy. I have tried various software packages, windows movie maker, ulead studio 6, pinnacle studio 8 and still no change. I just don't know what else I can try, please please please save the rest of my hair and suggest something I can try. Any help is Greatly appreciated. Adam.
  • Adam Bennett Aug 29, 2006
    Thanks for the super fast response!!!
    Unfortunatley this does not fix my problem. I did have the NTSC problem to start with but managed to fix that in a similar way.
    Now my settings all say PAL and my captured video almost wants to display colour as it flickers with the correct colour trying to come through but just doesn't quite get there.
    Here is a link to a sample of what I am getting.
    http://www.mydata.pwp.blueyonder.co.uk/f...
    Thanks, Adam.
  • pridmorej Apr 23, 2009
    Thank you JC for posting that article and thanks to the person for taking the time to write it. :)
    I installed the SuperVideoCap 6.0 software from downloads.cnet.com and once I changed the device setting to "Pal" (having previously tried it always reverted back to NTSC) it solved the problem and I didn't need to get a Firewire card.
    Yippeee!!! :)
    Problem Solver:
  • 11 Answers
Here is the solution from another group. I hope this helps. Let me know (It sounds like Belkin & M$ have some bugs to deal with) JC QUOTED TEXT There is a God!!!!!!!!!!!! I have just spent HOURS with a USB 2.0 DVD Creator trying to get it to work - the Ulead software that came with it was a piece of crap that I eventually after several tries got to install & then crashed every time I tried to open it - just like many of the posts I have found - could not solve the problem so gave up. I have spent considerable time combing forums trying to find the solution (I hate to be beaten!) - was close to giving up when I found this post - did not solve the problem but set me on the right track, & with a bit (lot) of luck - i am home!!! Here's what I did - the problem IS Windows Movie Maker defaulting back to NSTC. In WMM Set the format to PAL in "Options" - from memory this is in the Tools menu - sorry, I am in the middle of capturing video, so cannot access the menus to check. The only thing you then have to do was advised courtesy of an email reply from Belkin: "In windows movie maker, click on capture from video device and then choose the device and then there should be a configure button. You will need to change the video standard to PAL and then it should capture in colour" Sounds simple enought, but - PROBLEM - you try to do this but you cannot apply the change & it does not take - so you still have capture but no colour. Here is where luck stepped in - I decided I had spent too long trying to make this work so started surfing for alternate capture software. I came across several possibilites & downloaded them. Just picked randomly on one & installed it - beginner's luck!! - about time i got a break! When the software finished installing the program prompted me to install something else that it needed to run, which I did - don't ask me what it was - i was so blown away when i got WMM working that it has completely escaped me! Anyway, I installed the software (& the other required file), opened the software (which was a trial version) & attempted to capture - same problem - sound but no colour - then I recalled about changing to PAL, so went into the setup, changed the video to PAL - & bingo, all OK. I then (for some reason - madness maybe) went back into WMM, configured for PAL as advised, & double bingo - it works!!! - as soon as I clicked on PAL I could see colour video in the preview screen. Actually, I think what made me go back into WMM was that SuperVideoCapture looks & feels VERY similar to WMM . I have since uninstalled the trial software program, & am capturing in WMM with no problems - & in colour. The last piece of the puzzle (after the pain I have gone thru I couldn't bring you this far & not give you the final piece of the puzzle) - the software was SuperVideoCapture & the trial version can be downloaded at download.com - hope this gets around & ends the many headaches that people are having with getting the belkin hardware to work
Posted on Aug 29, 2006
  • James Cagle
    James Cagle Aug 29, 2006
    Since that did not work, it leads me back to my first thought, USB2.0 is not quick enough to handle the transfer in Color.
    When I have transferred in the past using USB from video I have had color issues as well as choppy video. After installing a PCI or PCMCIA Firewire card the problems went away both on my desktop and my laptop.
    There is a thread on Google groups that discusses this issue with your Belkin product.
    http://groups.google.com/group/microsoft...
    Good luck,
    JC
SOURCE:
I have been using a Belkin Hi-Speed USB 2.0 DVD Creator F5U228/ P74201-B to transfer VHS tapes to my XP computer. My new windows7 PC will not recognise it. Are there Widows 7 drivers available to download...
Unfortunately a lot of devices do not have Windows 7 drivers and some manufacturers are reluctant to provide these drivers for their older products.
Try going to the Belkin WEB site to see if there are Windows 7 drivers for your DVD creator.
THIS WORK AROUND MAY WORK.
Try running XP emulation within Windows 7 - for details how to do this, check out this WEB site.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Jun 13, 2011 | Computers & Internet
How do I copy the mini disc onto a dvd disc, is there a converter program I need to download so that I can then burn several mini discs onto a 2 hour dvd?
Hi, You can convert mini disc ( 8 cm diameter ) to a standard DVD disc via your PC. Please follow this steps : 1. Install your canon software/driver in PC 2. Install DVD creator in PC ( common software is use Nero scout) 3. Download your mini disc data to PC 4. Enhanced your data with Nero 5. Burn your data to standard DVD
Make sure you have DVD RW hardware in your PC.
Dec 04, 2010 | Canon DC210 DVD Camcorder
Have a JVC Digital Video Camera. Model No.
hi,
this is the mecenizam problem , you must have contact authorised person to fix it, because this work needs good expiriance so please contact authorised person,
don't worry its routing problem in same model
i have been fixx like same abuot 12 so keep smiling
Aug 31, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
Can't install Sony DDX-A-1010 USB device using Vista.
I had this same problem and found a fix. I do not know if how my system was broken fits your case but it could be worth a try. Looking at the user manual to the camcorder, it said to look in the Device Manager to make sure the driver was installed. It is supposed to appear in the DVD/CD-ROM drives. It did appear there, but with a yellow flag next to it. I have also been having a problem with my DVD/CD drive. Its driver has had a yellow flag next to it for quite some time. Then I realized I was getting the same error message on my camcorder as I had gotten with my DVD/CD driver "Hardware not found (Error 41)." (Please excuse if I am misquoting these error messages, now that the problem is fixed, I do not know exactly what they said. So, I am doing this from memory.) So, I did a google search on "dvd/cd code 41." It took me to a Microsoft website http://support.microsoft.com/default.aspx?scid=kb;en-us;314060. Apparently, if you install iTunes, Nero, Roxio Creator, or Zune, it can mess up your registry. This Microsoft website has a "Microsoft Fix it" icon you can click on, and it straightens everything out (it might mess up your installation of iTunes, Nero, Roxio or Zune though). Now, not only does my camcorder work, but my DVD/CD drive is fixed too.
Jun 27, 2009 | Sony Handycam DCR-DVD201 DVD Camcorder
How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV740&SelectOS=7
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
Mar 31, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
I need to transfer my 8mm tapes to dvd...
I assume that it is Sony DCR-TRV250 camcorder.
Go to camera menu and enable USB stream, like what Sony DV Direct says about change usb settings.
You can download user manual by clicking Sony Support.
Feb 17, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony CCD-TRV318 Hi-8 How do I connect it to a MAC?
you probably cannot connect you camcorder, you can just use video capture software when you play the dvd on your mac.
there are 100s of free to use capture software, just google & choose the one you like.
May 23, 2017 | Sony Handycam CCD-TRV318 Camcorder
Belkin Hi-Speed USB 2.0 DVD Creator (F5U228) Video Capture Logo
1,512 people viewed this question
Top Belkin Televison & Video Experts
Marvin
Marvin
Are you a Belkin Televison and Video Expert? Answer questions, earn points and help others
