Question about Nintendo Wii Console
Wii controller not working
No lights, no nothing when I press any button on controller. Tried new batteries and still not working. Other controller is so I think it is properly broken
  • rogue agent Oct 28, 2008
    i have new batts in the remote but there are no lights on it when i press buttons (tried em all) other remote works fine.
    looked everywhere for help, nintendo = none
    , google = none yet
Turn the wii off for a few seconds then back on. it resets the handsets.............
Posted on Apr 11, 2009
Wii Remote wont sync with the Wii
open the battery door on the remote, theres a red button. also there is a red button on the wii in the SD card slot press the one on the Wii then the one on the Remote.
Nov 28, 2013 | Nintendo Wii Remote Controller
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
The ON button on the Wii remote doesn't respond. Tried new batteries but still no response. No blue lights, nothing! Tried patting it, reset button, all instructions as listed in troubleshooting. Had since...
Try reseting the wii console. This is done by removing the battery from the botton of the console. There is a small battery bay held in by 1 screw. Leave it out for a day and after you install it make sure you press the conect button on the wii. (located under SD card reader door). And the connect button on the controller (located in battery compartment on back of controller). Good Luck.
Nov 24, 2009 | Nintendo Wii Console
My wii remote doesn't work!!!
Do you play with the second controller before? If you not the second controller must "bind" to the console. Open the cover in front of the Wii and press the red button there and then press the red button on the controller.
Sep 26, 2009 | Nintendo Harvest Moon: Magical Melody for ...
Wiimote unresponsive to anything
Have you tried restarting the Wii and then synching the wii remote to the wii ?
Just below the disk loader is a hinge you can open to insert a sd card, There is a red button - Push it
Take the battery cover of the wii remote, their is a red button - push it
Push both buttons close together time wise
Aug 12, 2009 | Nintendo Wiimote & Nunchuk Controller...
My second Wii controller does not connect. It used to work, but now no matter which reset I use (on the controller or on the console next to the SD card), nothing works. I have placed new batteries in the...
Have you tried one time syncing it? (By pressing home and then pressing reconnect controllers)
If you have make sure you're not trying to connect it in a single player game. If you do, the second controller will not connect.
Jul 27, 2009 | Nintendo Wii Remote Controller
Wii Fit board not staying on
Best suggestion is to make sure the game is fully loaded before pressing the power button.
If it's not working, make sure you press the red sync button on the Wii Fit Balance Board AND the Wii Console.
I know you tried new batteries, but make sure they are really NEW batteries (My experience is that the alkalines work best).
If it still doesn't work, then you may need to contact Nintendo direct.
Apr 08, 2009 | Nintendo Wii Fit for Wii
Wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Dec 29, 2008 | Nintendo Wii Console
When new batteries have been put in both controllers of the wii, indicator lights supposed to indecate power level of batteries instead of which all blue lights flash then stop and nothing happens, no...
If all the lights are coming on then going off again the controller needs to be synched with the wii. Once it is synchronized after all the indicator lights flash one should stay on indicating which player you are (1 -4)
To synch a controller to the wii:
Make sure the wii is in
Open the battery cover on the wiimote
Open the front panel of the wii
Press the synch button on the console
Press the red synch button on the wii mote
Should work for you.
Jul 04, 2008 | Nintendo Video Game Consoles & Games
Wii controllers wont work
Hi, i have just fixed the same problem with my controllers. You must re-sync the controllers. In order to do this, turn on wii, open back of first controller where batteries are and press red sync button, then open small compartment on wii beside where game goes in and press the red button, the first blue light should light up on your controller, repeat for other controllers, making sure to do this process for each controller seperately. Hope this helps!
Jan 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
700 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
