Question about Dell Dimension 3100 PC Desktop
Switches on & bleeps
Powers up bleeps , green light comes on but no power to monitor
  • 39 Answers
Try to check the cable connection between the monitor and the tower. what is the color of the LED light on the monitor?
Posted on Oct 27, 2008
The DELL E172FPb LCD Monitor (switch light flicks green)scr black
hi, extremely common problem for dell 17 in monitors. the capacitors and transistors on the power board internally have gone bad. to get repaired, it may cost 40-50 at a shop. i have repaired these in the past and they always come out well for at least 3 more years. may want to find another monitor though. if you would like steps on how to repair, let me know and i will find my old repair threads to give to you.
May 12, 2010 | Dell E173FP 17" LCD Monitor
My SyncMaster 910mp LCD TV monitor switch thus not turn on. The green light bleeps and the screen goes blank. Can you help?
ritchaddison, Problem could be inside monitor. If "cold-cathode-fluoresscent-lamps" fail to stay lit. problem might be the "electronic ballast" circuit needs work done on it. Also check the "switch-mode-power-supply" for typical failure modes that result in "black screen" complaints. Remember this!! Your monitor no different than any other brand of CCFL back-lit LCD display in it's basic design and operation. Software not problem. Only you or qualified electronics technician will repair this unit. Read my and other LCD monitor tech's fixya profiles to make decision on what option you will use on 910mp unit. 12fixlouie
Mar 18, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
When switching on PB not loading and is realising loud bleep
yes the beep pattern. btw , try checking your memory if you have 2 of them on try removing the other 1 then turn on pc. n do it vice versa. if
Jan 22, 2009 | Acer Aspire™ T180 PC Desktop
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
Monitor Problem
its a power prblem
u need to change the internal power conector
Sep 03, 2008 | Samsung SyncMaster 793DF 17" CRT Monitor
Monitor Problem
First check the power switch with a multimeter,if its correct then check the power supply part of the monitor circuit. If you are having any problem with that part change the FET with another.
Aug 27, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor won't come on
Check the power cable of the monitor make sure everything is properly connected.
May 10, 2008 | Acer AL718 17" Flat Panel LCD Monitor
Power issue with LCD Monitor
Try another power adaptor. Check the delivered voltage and go get a universal power adaptor that has a switched for varios voltages and a number of connectors. Simply match connector to the voltage switch.
May 21, 2007 | Princeton Digital LCD17 17" Flat Panel LCD...
Dell Dimension 3100 PC Desktop Logo
110 people viewed this question
Alun Cox
