Resetting 80 routine maintenance message on lexmark w840
SOURCE: Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
brother mfc9420cn factory reset
Posted on May 30, 2008
SOURCE: Reset Lexmark T644
1. Turn off the printer. 2. Press and hold (check) and .(right arrow). 3. Turn on the printer. 4. Release the buttons when Performing Self Test displays. The message CONFIG MENU displays on the top line of the operator panel. 5. Select Reset Maintenance Count from the Configuration menu. 6. The message Reset Maint Cnt=Reset displays momentarily. Press (check) to reset. When the reset operation is complete, the menu returns to the Printer Setup Reset Maintenance Count Screen. Scroll down to the Exit Configuration Menu and Press Select to Return to Ready status.
Posted on Jan 26, 2009
  • 412 Answers
SOURCE: Lexmark x642e MPF Reset maintenance counter
80 Scheduled Maintenance Message
The 80 Scheduled Maintenance error appears when you first power on the printer. The printer will still work even though it is in a maintenance condition. To clear the message temporarily and continue using the printer, simply press the Go button on the printer's screen. (For details on scheduled maintenance procedures, refer to the User's Guide for your printer.)
This message appears when the printer maintenance counter determines that maintenance is due. For a list of the part numbers of maintenance kits for most of the printers that require them, click here.
Note: The printer will still operate even if you do not have the kit replaced, but you may experience some print quality problems.
You are required to purchase the maintenance kit and have it replaced even if the printer is still under warranty. Some maintenance kits can be installed without the assistance of a technician. However, some warranties cover on-site installation of the maintenance kit by a technician AFTER you have purchased the kit. For more information on the warranty terms for the maintenance kit, click here.
Source: Lexmark KnowledgeBase
Posted on Mar 09, 2009
  • 11 Answers
SOURCE: 80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Posted on Jun 17, 2009
  • 1751 Answers
SOURCE: how can i reset page
Hi
There is no way to reset it
Pls vote me to keep me alive
Posted on Nov 21, 2010
Routine maintenance required needs to be reset
Routine maintenance is required ie fuser, charge roller, transfer roller & pickup rolls need to be replaced.
Apr 02, 2014 | Lexmark T650n Laser Printer
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
I have a printer Lexmark W840. On the display there is a message "84 Replace PC unit" - what does mean?
The PC cartridge needs to be replaced. If you have just installed a new unit, please check if the PC cartridge is installed securely.
For further assistance please contact Lexmark Technical Support.
Feb 16, 2011 | Lexmark W840 Laser Printer
How reset the printer maintenance counter for the lexmark t642
Here's an article in the Lexmark website on 80 Scheduled Maintenance" Message Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Included in this article are instructions on Resetting the maintenance counter to zero. Just click on this link: http://bit.ly/9pzU7R. Read thoroughly and follow the instructions carefully. Scroll down for the instructions on resetting the maintenance counter.
NOTE: RESETTING THE MAINTENANCE COUNTER SHOULD ONLY BE DONE ONLY AFTER REPLACING A NEW MAINTENANCE KIT.
Jun 29, 2010 | Lexmark T642 Laser Printer
Getting a 80 Maint. Error. Replaced the fuser. How do I reset the paper count?
Go to Config by turning off the printer. Then press and hold Select and Return buttons while turning on the printer. Once in Config Menu, choose Reset Maintenance Count.
NOTE: The error indicates that the printer has already printed 300k pages, worn out transfer and charge rollers. You should've replaced the maintenance kit = fuser, charge roll, transfer roll and pick tires. Otherwise, you'll ge having print quality issues.
Jun 15, 2010 | Lexmark W840 Printer
A fuser unit
A transfer roller
A charge roller
Jun 11, 2009 | Lexmark T522 Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Lexmark W480 jam in D
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
Mar 02, 2009 | Lexmark W840 Printer
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
281 people viewed this question
k24674
jasbo
jasbo
