Question about Dell OptiPlex GX270 PC Desktop
Checkpoint [Krst] Previous attempts at booting have failed
5 Suggested Answers
  • 139 Answers
SOURCE: desktop GX270 eats moniters, not booting now
ya
just try and unlpug all ur devices such as web cam, printers, speakers and restart the system.
go to bios and load system defaults - > restart it should work.
Else replace system battery
Posted on Jan 30, 2009
shoib127300
  • 55 Answers
SOURCE: my dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Posted on Mar 17, 2009
dixibabe82
  • 54 Answers
SOURCE: My Dad is receiving an error on his dimension 3000
As soon as you start the computer up start looking for a small message stating which key to press for recovery or diagnostics. May be F12 or F11. If you don't see anything, start over again and start pressing the F8 key. This should get you to an area that will let you start in Safe Mode. If you can get there, once you are in safe mode - at the very least backup any documents or pictures. Let me know if youget this far and I can instruct you further.
Posted on Mar 26, 2009
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
Alert sound dimension
Please do a fresh install or try to use System Restore to go BACK before this problem happened.
Jun 08, 2013 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Dell 8300 failed at checkpoint krst
Try F12 or ESC or Del. Google search the error message by Make and Model of desktop.
Mar 04, 2013 | Dell Dimension 8300 PC Desktop
My dell 4600 says several previous attempts at booting have failed at checkpoint (rst)
sheila_barnu,
This error could very well be a motherboard failure. I found a Dell Community Forum link to where the resolved the error. Click the link below view.
Dimension 4600 Error
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2013 | Dell Dimension 8400 PC Desktop
How do I fix "Optiplex 760 failed at checkpoint [WRIT]" ?
This computer has known issues with the USB hubs which will throw this code. If you used a USB hub for a monitor or such it may have crashed the driver. Have you tried booting without any USB devices connected? If not please try.
Jan 16, 2013 | Dell OptiPlex 760 MT Desktop Computer
How do I fix this error "Previous attempts at booting this system have failed at checkpoint USB0?
go into bios and disable usb ports it should tell you while its booting up what key to press to get there like f1 or f2
Dec 08, 2012 | Dell Precision Workstation 670 PC Desktop
When booting my dell optiplex dimension 270 i get an alert message of checkpoint [krst]
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Dell OptiPlex GX270 PC Desktop
I keep recieving the message...previous attempts at booting this system have failed at checkpoint(poke).for help resolving thisnproblem please contact dell tech support.
If you made a backup disc use that disc and run the repair files options when you boot up your computer. Sound like one of the files got corrupted on hard drive.
Apr 18, 2011 | Computers & Internet
Can not boot the system
if u realy want to make ur PC facotry fit....
visit my site
www.sureshayyar.110mb.com
Format Disk page
all detailas and necessary tools are available for download
Feb 05, 2010 | Dell Dimension 8400 PC Desktop
Can't Do Anything... NEED HELP!!!
"Alert previous attempt at booting the system has failed at checkpoint emem {EMem}."
This is a No Post issue and if youre going to check the quadpack it will show yygg which indicates memory failure.
Quick Step : Reseat memory
If cust has more than 1 memory, test each memory on each slots until you find the memory that’s causing the error message and send a replacement for the faulty memory.
May 19, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
1,066 people viewed this question
Alun Cox
