Question about Nintendo Wii Console
Wii power light
The power light will not come on the wii at all and cannot remove the disc either...please advise..
thanks,
Bart
Unlugged power cord from console and wall socket for about 5 min plugged back in and console worked
Posted on Oct 28, 2008
Now that we have NetFlix on the Wii the off light turns from red to yellow. When you leave a disk inserted when the yellow light is on (which I guess is really the off) the disk is warm when ejected. Is...
The disk is warm because technically the Wii is still running, albeit in the background now, so yes it is now normal. I'd advise you...pain in the tuchus it may be...to remove the disc before you shut it off...heat, especially prolonged, is an enemy of discs...that's why they advise you not to leave CDs in your car in the summer... :)
Aug 28, 2012 | Nintendo Wii Console
When i insert the Lego Indiana Jones 2 wii disc the following error comes up on screen - error has occured please remove disc, turn off the console and refer to your manual for troubleshooting. There are...
Hi. I have a wii and this happens to me with mario strikers and smash bros, I tried everything to solve the problem bu nothing worked, then i hacked the wii, i made backups of the games and now i can play them without any error I thing that the discs were damaged or something if you have bought the game recently change it. Good luck
Aug 31, 2011 | LucasArts Entertainment Company LEGO Star...
Just got wireless internet..and trying to hook to netflix....help
Sign up at the Netflix website for the Streaming Disc. Netflix will send a specially programmed disc to setup the Wii for watching the movies. When the disc arrives Netflix will provide instructions on how to install onto the Wii gaming console.
Apr 04, 2011 | Nintendo Wii Console
My wii keeps saying cant read disc i have been out to games to buy a wii lens cleaner and still the same can anyone help please
does it say an error has occurred press the eject button, remove the game disc, and turn off the power to the console. please read the wii operations manual for more instructions? if so you probaly need to replace the laser light in your wii it shouldn't cost more than $50.
Feb 21, 2011 | Nintendo Wii Console
Bought 2nd hand wii fit, have just loaded disc and replaced batteries in board but power light not staying on board, flashes for about 30 seconds and then switches off. Does it need to be synchronised with...
    Hope this helps
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
Mar 27, 2010 | Nintendo Wii Fit for Wii
Unable to read disc error
Laser or motor to the laser is bad
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Jun 21, 2009 | Nintendo Wii Console
Can't access Wii Play games anymore
You will have to replay those games to unlock them. Reformatting your Wii console resets all saved game information and so it will not recognize previously acquired unlocks.
Sorry about that.
Note: If my advise isn't helpful, please vote accordingly. Please don't rate this solution as inappropriate unless you truly believe it to be so.
Thanks for using Fixya!
Mar 25, 2009 | Nintendo Wii Play for Wii
Hi, I have a 1999 mitsubishi shogun and all my internal lights as well my clock have gone off.Also when press the remote control fob to unlock or unlock the doors, the locks rattles for about 30 seconds...
bart , I about the power windows locks going berserk, i use to have that same probblem.one of the door lock mechanism is bad. you"ll have to test each one to find out which is bad by removing the conector from each and appling electricity (thats 12volts) directly to it.the bad one will do the exact thing you spoke about.
Nov 29, 2008 | Mitsubishi Montero Cars & Trucks
Wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Aug 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
