Question about GE Kitchen Ranges
Model#JMP28GOV1WH code F-3 comes on when turning oven on
Code F-3 COMES ON WHEN TRYING TO SET TEMP ON OVEN
jsrock516
  • 5911 Answers
SOURCE: f-3 error code
F3 indicates a failed oven temperature sensor. Your model number indicates that your range is manufactured by Roper. They recommend measuring the resistance of the oven probe (at room temperature). It should read approx. 1100 ohms. If the reading is bad, replace the oven probe. This is a repair you can perform yourself. The probe is mounted on the back of the oven wall in either the upper left, or upper right-hand corner. The part number is 252618 and costs (like you said) about $73. If you need guidance on how to remove/replace or measure, let me know. I hope I do not insult your intelligence. I generally ask, because some people are not savvy when it comes to electronics. I hope this information is helpful.
Posted on Jan 29, 2008
aborcass
  • 2651 Answers
SOURCE: temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Posted on Oct 07, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 19, 2008
aborcass
  • 2651 Answers
SOURCE: oven not turning on f31 code kenmore
may be a real simple , lets try this. unplugh the unit, and uscrew rear panel of the unit, there is a thermostat that may have tripped, very small maybe the size of a quarter, with 2 wires on it, easy to sppot because it will have a small red button atop of it, its resettable, so if it did "trip" melrey reset and your on your way,there are actuallly 2 of theese thermostats on your unit, and actually a more common one to trip would be the one in the control panal, so id prblaby check this one first, to acces it remov eht knobs, then wehere the knobs were are "large plastic lock washers" holding down the control panel, one around earch knob opening, after ermoving htem the control panel will lift up and lean over. i belive there are 4 screws to remove the clock(plenty of slack in wiring no worry)after thats out of the way, if you look down under behind the switch to right is the same resetable thermo(lok for the the red button) and with a small long screw dricer youll be able to reset it, this should cure you issue. sounds like a ton of directions but should take no maore than 20 min, to check em both
Posted on Dec 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: When everything is set to come on,the oven will not come on.
Make sure the glow bar ignitor is working in the oven.
They can glow and still be bad because of poor resistance.
Posted on Feb 22, 2009
The oven will not stay on. I replaced the ignitor in september. The oven comes to temp but turns on and off.
That's normal operation. As the set temp is reached the burner turns off. When the temp falls below the set temp the burner turns on to compensate.
Nov 09, 2014 | Kitchen Ranges
Kenmore wall oven model 911.4088816
i believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Dec 18, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Samsung oven error codes
you need the service rep or repairman
Jan 12, 2012 | Ovens
What's an f1 and f2 code mean???
The F1 code means that a button on the touchpad is stuck
The F2 means that the oven tempature was at least 100 degrees over what the temp it was set to was
the F1 will come sometimes if the ribbon connection on the touchpad doesnt fit well into the control board and other times it comes because the touchpad is defective
the F2 comes up because the control has measures the temp and thinks that when it set as lets say fro instiance 350 degrees the control thinks the temp ahs reached 450 degrees(100 plus over) typically the thing wrong when the F2 comes up is the oven sensor at room temp to be between 1060-1100 ohms
However if you are getting both error codes at the same time the only thing common to both is the oven control and if both at the same time i suspect the control is the problem
GENE
Sep 06, 2011 | Whirlpool Kitchen Ranges
Oven does not "burn" steadily when set below 300 degrees.
Sounds like you have a bad oven ignitor and oven burner tube. install a Amperage meter on one of the oven ignitor wire, It should draw above 3 AMPS, if it is below then you have a bad oven ignitor, or just change the oven ignitor to see if it makes any difference. Have fun.
Dec 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
F-3 code on GE gas range
Hi, You may have a Open or shorted oven temperature sensor (RTD) that should be replaced.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Please rate and have a great day:)
May 18, 2009 | GE Kitchen Ranges
Get f-3 code after oven on for awhile
F3 is Open oven temperature sensor circuit, to fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Jan 02, 2009 | GE JRP15 Electric Single Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
